Question about Kenmore HE2 Plus Front Load Washer
My washer shows an error message of f 35 - Kenmore HE2 Plus Front Load Washer
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Nov 08, 2010
WHIRLPOOL DUET WASHER MODEL #WFW9600TW01 F-35 & F-28 ERROR
The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
Oct 28, 2014 | Washing Machines
Washing machine Front Loading Automatic Washer showing error code 35?
Hello This would be a pressure sensor failure.
Will need to be replaced.Whirlpool has them in stock or you can have a service person come out.
Jul 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore Front Load Washing machine and I am getting an error message f-35. what does that mean? It is an HE 3T Steam. Once I get this error code, the unit stops and unlocks.
This washer seems to have multiple solutions for the f35 error,
Unplug the machine for an hour to reset the computer
Clean the filter The panel below the door has 3 screws (mine was a star shaped screw). The white cap screws off. yopu may have to cancell the error using "stop".
Please Vote !!
May 15, 2010 | Kenmore Elite 45986 Front Load Washer
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Error F-35-4
problem konica F-35-4
Oct 15, 2007 | Office Equipment & Supplies
Kenmore HE2 Plus Front Load Washer Logo
80 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
