Question about Palm TX Handheld
Palm Tx crashes constantly when I do search on Contact
When I do search on Contacts, program stops and Palm Powered screen appears.  then shows date and time and box with message "Installer not compatible with this device.  Check with manufacturer." OK   Can delete installer now .done.  Then can go back to program
  • 2,794 Answers
You should restore your Palm software.
Have you docked it recently?
Posted on Jun 19, 2008
Need instructions on a hard reset
On your handheld, launch the Prefs application. Under General, select Security.
If the Password box says "Unassigned," tap the box and create a password for your handheld.
Once the password has been set, remove the stylus. Disconnect your handheld from the AC charger, if connected.
On your handheld, hold down the Power button.
While holding down the Power button, use the stylus to press the RESET button on the back of your handheld.
  1. While still holding the Power button, the screen will show the Palm logo and a progress bar. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
  2. A message will appear warning that you are about to erase all the data stored on your smartphone. Press UP.
  3. You'll see a series of Palm logo screens, then a prompt to tap onscreen targets. The Factory Reset is complete
Mar 03, 2011 | Palm TX Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
How do I perform a hard reset?
press and hold up on the navigation key, while holding up press the reset button with your stylus, continue to hold the up button until you see "palm powered" come up on your screen.
WARNING: this will erase ALL data on your palm and restore to factory settings, so First hotsync and back up all contacts, data, and programs before doing this. Also fire up the palm desktop to make sure everything was backed up before you hard reset your device.
Jun 20, 2009 | Palm TX Handheld
Need to move contacts in Palm Desktop to new user name
On your Palm Desktop, under username PalmUser40, select the category view of 'All'.  Then press Control + A to select all contacts. Then press Control + C to copy them all.
Then change the username on the upper right to 'misty'.  Then go to contacts, under category 'All', and then Control + P to paste all contacts.
This will most likely not keep all the category names, but all your contacts will be copied in.
Then hotsync to sync to your Palm TX.
May 19, 2009 | Palm TX Handheld
My TX crashes every time I try to hot sync
You could delete that app if you want, however I would go into hotsync config and sync only one section at a time, such as Notes, but not contacts or calendar (or anything else). If it works then add a section, such as contacts. Keep adding sections until it malfunctions. Pimlico software makes a product dbfixit ($) that can fix database (blob errors). You can download and install it, and it will report on (but not fix) any errors it finds.
Feb 04, 2009 | Palm TX Handheld
TX in a crash, reboot, crash cycle since I deleted contacts file
When reset button is pushed, the Palm screen comes on in color, then in gray, then the screen goes blank. Can I repair it?
Jan 11, 2009 | Palm TX Handheld
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
WiFi Icon on Palm Tx not showing on taskbar
You should try reloading the software back into the TX. In order to do it, you will have to erase your TX memory. Make sure you back up your files first.
To erase the memory press the reset button until the reboot screen appears. Hold down on the power button until the erase memory screen appears. Select yes. Reload software from Palm CD.
Jun 05, 2008 | Palm TX Handheld
Trouble syncronizing palm TX
If you look on your handheld, tap the Hotsync icon once.
This will tell you the last time your Palm was synced.
Also if you hold your mouse over the Hotsync icon on your computer in the bottom right hand corner, this will tell you a last Hot sync date.
See if the two dates/times match up.
You can do a search on your computer for a "hotsynclog" file, this will give you a detailed list of all the processes that occurred during your sync. I would see if there are any errors listed there.
Also, you may want to make sure the Palm names match up with what you have on your Palm and the computer. When you click Hotsync on the Palm once, a name should appear in the upper right-hand corner. This name should also appear in the upper right-hand side when you upen Palm Desktop. There will be a white box with a name showing and an arrow pointing downwards. Make sure the two are the same as well and see if your information appears then.
Jan 04, 2008 | Palm TX Handheld
Palm TX Handheld Logo
71 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
