Question about KitchenAid Architect KEBS208S Electric Double Oven
KEBS208DSS8 double oven - bottom oven door will not stay latched shut - please help
  • 2,069 Answers
I think you should then replace the door latch for your whirlpool oven. it is part number AP3135403
Made by WHIRLPOOL. and can be purchased here.
Regards
Posted on Nov 08, 2010
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Superba oven will not open - seems like it is locked (similar to if using self clean option) however, it is not. This is a double oven - the bottom oven opens and operates normally. Top oven...
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
Nov 15, 2017 | KitchenAid Ovens
Can the top and bottom doors be switched? (jenn-Air double oven jjw9430dds)
I have this same problem, top door won't close completely and the light stays on. Help donmash@aol.com
Nov 24, 2010 | Jenn-Air JJW9430DDS Stainless Steel...
Good Morning: The self cleaning mode engages, locks the oven on the bottom, but does not clean. On the top, the latch does not engage at all on the self cleaning mode. What to do?
A safety feature on the oven door latch is preventing it from going on to clean. Find the reason the door wont latch on top section and it should clean then.
We know your controls are working asking the clean cycle to start because your lower door latches.
SO
Some things to check :
1. Bent or worn out door latch or striker or catch assembly
2. No power to motor to move latch assemble
3. Board for self cleaning may have fuse out or be bad entirely.
4. Motor assembly that moves the latch could be bound up or worn out
If this helps you understand your problem please rate me as high as you can and thank you for using fix ya. Good Luck and God Bless.
Mar 27, 2009 | Viking DEDO205 Stainless Steel Electric...
No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | KitchenAid Architect® Series II KEBS208S...
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
KitchenAid Architect KEBS208S Electric Double Oven Logo
117 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
