Question about Sharp LC19A35M 19 in TV
We hooked up our LCD HD 19" TV up to our HD
  • 320 Answers
Try to disconnect all the connection cables and reconnect again. If still don't receive any sound, your HDMI cable is faulty.
Posted on Nov 07, 2010
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
Need Help how to setup HD on sansui HDLCDWB
In order to set up HD you need either an HD antenna, or a digital cable/satellite box. If you have cable or satellite you have to make sure you have HD service through your provider. If you do just hook up your box to your T.V. using either HDMI or component (blue, green, red). Then you'll have to look through your channels to find out where your HD channels are.
May 05, 2011 | Sansui HDLCD-1900 19 in. LCD Television
When i hook up my ps3 to an emerson 19 in tv with an hdmi cable it says format not supported
LCD Emerson only support screen with a 1440 x 900 720p resolution.
And PS3 has support 1080p or full HD.
You must arrange output HDMI resolution to 1440 x 900 or to 720p.
thanks.
Mar 21, 2011 | Emerson LD195EM8 19 in. LCD TV
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
We need to hook up a dvd player with satellite in
You can try to connect the DVD and the TV with a HDMI cable. after this, you have to disable the sound from the TV's speakers and enable the sound from the DVD.
Oct 27, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
What type of cable for laptop to Tv?
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
May 05, 2009 | Sharp 19 in. LCD HDTV
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Sharp LC19A35M 19 in TV Logo
223 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
