Question about Western Digital Computers & Internet
Where can i buy a western digital power supply board for inside a 600GB external hard drive. part number E03A-A3-80021-06-0 or CE3C102490900BDD
  • joecoolvette
    joecoolvette Dec 10, 2010
    Harder to find than hen teeth. One of the reasons is, if a harddrive has a head crash, (Read/Write Head into Platter), the circuit boards usually go in the trash with the bad harddrive. Second reason is that 'Braniac' (Or greedy) repair techs take take the boards off, and sell them to data recovery specialists. They may use them to fix the defunct drive, then charge you by the hour for putting the info on a New drive, or disks, or thumb drives. (And you know they aren't going to sell the boards!) Buy a new, or used WD with the same model number, use it's board on your defunct WD to retrieve information, then put it back on the new/used drive.
Just buy a new off the shelf SATA HDD enclosure and put the drive in the new enclosure.
Posted on Dec 10, 2010
WD elements SE 1TB Portable hard drive will power up and disk will spin but not showing up in my computer....
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, and you'll get a significant discount.
Nov 04, 2010 | Western Digital 500GB ELEMENTS 500 GB USB...
My western digital hard drive doesnt work. it lights up so the power is fine but it doesnt get reconised on the computer or media player. i hav alot of things on it and really need it working again......
* USB cable
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
Nov 03, 2010 | Western Digital 500GB My Book Pro-External...
Harddrive won't start
* USB cable
Nov 02, 2010 | Western Digital WD Passport 250GB Portable...
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows...
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Oct 24, 2010 | Western Digital Passport WDXML800UE...
My power supply does not seem to be working.
You need the part number off the drive and contact western digital to get a replacement power supply if it is not in warranty.
May 06, 2010 | Western Digital Elements powered by WD 320...
Not showing blue light nor processing anything
hmmm..disconnect from computer completely. Then simply turn off power for around 5 min. Then just plug in and power up(no computer connection). I've seen this too. It MAY be related to a heat issue. Make sure there is NOTHING on top where holes are for cooling.
Dec 05, 2009 | Western Digital My Book Home Edition 500...
Hard drive will not power ON
I have had my own experience with Western Digital and their policy is to not sell or provide parts in order to replace damaged parts in an otherwise functional device.
Your options would be to send it in to WD for a repair and strictly a repair. They may replace the power supply.
The other option is to buy a used/off-market case or power supply which matches your drive's supply.
I had a harddrive burn a hole through one of the interface chips on the bottom of the HD and was told there was no way I could get it repaired or recover the data as it was. However, I found an exact match for model and type of the drive and a near enough year to the one I had and exchanged the interface boards on the drive, and I'm using the drive today as my main boot disk.
All you need to do is replace the power supply. Try Ebay for your external drive model number, there may be cases with no drives which you could buy that have functioning power supplies, or power supplies alone.
If all else fails, you can do what I did - buy another, matching product, exchange the broken part from the new one you get with the old one, recover data, and swap the power supply back again, then send the old drive to WD for replacement. You can attempt to resell the RMA'd (returned to WD drive) on amazon/ebay and use the new one, or keep the new power supply in the old device and use it, and sell the drive out of the case, or keep the drive and use it. I expect the drive inside the external case should work as a normal drive.
Dec 16, 2008 | Western Digital 500GB My Book Pro-External...
Computer fails to recognise my external hard drive
I would suggest the external casing of the harddisk that contains its power supply is busted, so you need to change the casing or remive the harddisk from the casing and connect in inside
Feb 16, 2008 | Western Digital Caviar WD2500BB 250 GB...
Computers & Internet Logo
1,320 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
