Question about Echo 24 In Double Reciprocating Double Sided Hedge Trimmer HC165C
Blades locked up - Echo 24 In Double Reciprocating Double Sided Hedge Trimmer HC165C
    Guru:
  • 479 Answers
Ensure blades are sharpened. If there are burs on blades they can seize.
Blades should be lubricated with WD40 , waste oil or other lubricant.
The bolts holding the two blades together shouldn't be too tight.
Posted on Dec 10, 2010
What may be cause for trimmer's unusual noise?
Have you lubricated the blades? You can buy spray lube (Remington Shaver Saver) for this purpose.
Feb 11, 2015 | Remington HC-921 Hair Trimmer
How do I get my transmission to unlock? It locked when one of the blades fell off. I have replaced the blades.
raise it off the ground get another person the push lever to try to forcse fod in already in then roll when foward backwards hard until engages if hydropump squeels replace pump it will not go into gear with a bad pump
Sep 02, 2014 | Yard Machines 710-1007 Tt Screw:...
How do I safely replace the blades without removing the mower deck? I bought a devise at Walmart that is used for locking the blade but not sure how to use it.
If you lift the mower and block it up or drive it up on loading ramps anything to get at the blades disconnect the spark plug wire put the blade lock tool so that when your loosening the nut it comes up preventing the blades from moving loosen the nuts replace the blades then reverse the procedure installing the tool on the other side of the blades to tighten it. If you have access to someone with a 1/2" air impact wrench/gun it is really much easier and the use of the tool is normally non-existent.
Jun 11, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Baldes locked up
May 01, 2011 | Remington At3017b Hedge Wizard
How do you replace blades on a 22-540 delta portable planer?
Unplug the machine and crank the head up (open) as far as it will go. Underneath, in the middle of the head there is a bar with two blades on it held in place by a lock bar and six to eight screws. Remove the screws and carefully pull the blade out. The blades are double sided so if you haven't changed the blade before, they can be reversed. Turn the blade around so the sharp edge is out and reinstall it. If both sides are used, install new blades with the blade lock engaged in the channel in the middle of the blade. Make sure to get the screws in tight.
Oct 28, 2010 | Garden
I HAVE A JOHN DEERE RIDING MOWER AND I AM TRYING TO CHANGE THE MOWER BLADES, THE BLADES WILL NOT LOCK SO I CAN TURN THE NUT THAT IS HOLDING THEM ON. SO HOW DO I LOCK THE BLADES SO THEY WILL NOT TURN?
you need to remove mower deck....and with correct size wrench hit it wrench with copper hammer to shock it loose....then do the same when tightning them up
Aug 11, 2010 | John Deere Garden
The blade lock is not locking . When you put pressure on the blades they pop off
Most makes of clipper including Oster, Andis, Wahl have a latch which is depressed to release the blades. The latch is commonly situated under the hinge assembly and holds the blade with a simple hook at the tip which catches on the blades.
If the blades will pull off without depressing the latch, chances are the tip has broken off and will require replacement.
Undo the two screws securing the hinge into place and remove both parts, when fitting the new latch make sure the spring ends of the hinge locate through the holes on either side of the latch.
Dec 16, 2009 | Andis Health & Beauty
Husky lock 509. My machine does not cut . There is something wrong with the blades
Be sure the blades are "raised" properly - did you have them lowered so you could sew without cutting? Maybe they are not locked back in place. Is the machine set for rolled hem? Re-set it for regular overlocking. Even if the blades were blunt, you should still be getting some sort of cutting happening. Blades are reasonably easy to replace yourself but getting hold of replacement blades can be tricky.
Oct 11, 2009 | Husqvarna Sewing Machines
Dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
May 18, 2009 | Garden
Blades won't stay on mixer
if this is new then i would just take it back it may be faulty.
Oct 27, 2017 | Wolfgang Puck Food Mixers
Echo 24 In Double Reciprocating Double Sided Hedge Trimmer HC165C Logo
483 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
