Can you go into safe mode after you are already in windows?
    Genius:
  • 1,016 Answers
No you need to turn the PC off and press the F8 button when you switch it back on, until you get to the BIOS selection screen. Hope this helps.
Thanks
Jason
Posted on Nov 07, 2010
    Guru:
  • 2,178 Answers
No, you have to reboot and press F8.
Safe mode how do I leave safe mode?
if your device/pc wont leave safe mode, then you have either damaged your OS or you just have it enabled in startup.
within safe mode do the following:
Windows Key + R>
In the Run window type "msconfig" without the ""
In msconfig go to the "BOOT" Tab
if enable you will have Safe Boot Checked,, Simply Uncheck it and restart!
if its already Unchecked, then you have a bigger problem with your os and you might need to perform a system restore. i hope this helps!
Aug 18, 2017 | Computers & Internet
On my window update i get error code 663
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
The 633 error is a connection problem that appears every time you try to use the modem on your computer.
It states "modem is already in use" and prevents you from accessing the Internet.
This problem mostly appears when a device with incompatible drivers has conflicts with the modem driver on your computer system.
The major software that causes this error is the Palm Pilot Software.
With some simple troubleshooting steps, resolve this modem communication error.
Shut down all currently running applications and restart your computer.
Press "F8" repeatedly before Windows begins to open the Windows Advanced Options Menu.
Scroll down and select "Safe Mode." Press "Enter" to log into Windows Safe Mode.
Safe Mode is used for troubleshooting and repairing system components.
Click the Windows "Start" button and select the "Control Panel."
Double-click "Add or Remove Programs" to open the programs window.
Click "Program and Features" (Windows Vista users) and select "Uninstall a Program" to open the programs window.
Click the incompatible software (e.g., Palm Desktop and Synchronization Software) and select "Change/Remove."
Click "Yes" to confirm and uninstall the program from your computer.
Restart your computer normally to complete the process.
Hope this helps
Nov 13, 2012 | HP Pavilion A6400f Desktop PC, Refurbished
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I have a Lenovo U350 ideapad. When i rebooted it, it keep coming up Windows Error Recovery. I tried all the options (Safe Mode, Safe Mode with Networking, Safe Mode with command Prompt, Last known good...
Welcome to Fixya
Looks like the Windows OS is already messed up. You should be able to boot the computer to safe mode to troubleshoot the issue. In your case, it is not booting up to safe mode then the only way to use your computer again is to restore it from the factory default state. If you want to do that, just turn off the computer then press the ONE KEY button located beside the power button then follow the on screen instructions.
Thank you for using Fixya!
Sep 05, 2011 | Lenovo Ideapad U350 Laptop Notebook
MY ASUS F80Q WONT start up, it stuck in the Microsoft corporation
Hi. First option: For that symptoms try restart PC then before booting press F8 to see.(for windows xp professional and home edition. operating system )
safe mode safe mode with networking safe mode with command prompt enable booth logging enable VGA mode last known good configuration (your recent settings that worked) select this option by highlight then press enter key. if same problem? restart PC again then select safe mode wait for booting. already use that option not yet happened same problem. jimmyverdade_46.jpg
Second option:You need to reinstall fresh installation of operating system like windows xp,windows vista,windows 7 version etc.
Hope can help you.
Jun 17, 2011 | ASUS F80Q-X2AM Notebook
When i turn my acer aspire one computer on, a black screen pops up saying that Windows did not start successfully. it gives several options to try including Safe Mode, Safe Mode with Networking, Safe Mode...
hi, i had the same problem to before, basically if you already tried all the safemode and still doesnt work your OS is already corrupted. So the solution for this one so that you'll still be able to use your computer is by reformatting it. hope this helps, goodluck..
Jun 07, 2010 | Computers & Internet
Can't enter safe mode
Try a normal system restore after logging in as Administrator. Otherwise reinstall windows on the same partition by using the original OS CD and just repair when prompted to(DO NOT TRY ATR)...sodeep
Mar 21, 2009 | Microsoft Windows XP Professional
Still, No luck with laptop
Your laptop is booting to a Windows Desktop, so there is no hardware fault or Ram isssue. You may have a lack of free space on C:, but I would suggest the following:
Shut off your laptop if its not off already. Restart after a moment and press F8 while booting, this should get you a startup menu for using Safe Mode. Select Safe Mode and then your presented with an OS choice, usually your windows installation is already highlighted. If it is hit enter, if it isn't use the up/down arrow keys to highlight it and tehn hit enter.
Once you reach a desktop environment you are warned that you are entering Safe Mode, acknowledge that notification, you will proceed into Safe Mode dektop. Does your mouse do what you want? When you press the Windows Logo key on your keyboard does the start menu pop up?
If so, let us know with a reply using the comment box below. We can take some measures to get your problem taken care of shortly.
Regards,
Worldvet
Jul 23, 2008 | Acer Aspire 5100 Notebook
My computor seems to have frozen up the cursor is not moving
You should try starting in safe mode. Shut down the computer completely - switch of - wait a minute and then switch on...
To get into the Windows XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the Windows Advanced Options Menu . Use your arrow keys to move to "Safe Mode" and press your Enter key.
Once you are in safe mode you shold be able to investigate the problem.
Let me know how you get on.
Apr 16, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
