Question about Sony DAV-SC8 System
Where can i obtaincable attachment plug - Sony DAV-SC8 System
  • ken_horne Nov 07, 2010
    speaker cable plug into unit
    speaker cable plug into back of unit
    Top Expert:
  • Sony Master
  • 76,649 Answers
Can you please clarify what type of plug this is? is it the power plug for the wall? If it is a plug or cable for component hookup let me know exactly what it is you need, Ebay is a great source for these types of cables
Posted on Nov 07, 2010
  • yadayada
    yadayada Nov 07, 2010
    Radio Shack electronics store can supply any type of cable you need, also you can buy them on ebay.
  • yadayada
    Once again Radio Shack can supply this or any store that sells electronmics parts and accessories, that would include Best Buy stores, Sears will have most likely anything you need.
Trying to attach the plug wires on my '93 Camry to the rotar cap. What's the sequence ? My manual doesn't have my engine model diagram. F 5 LE
The internet has a picture-google it
Next time make a drawing
Mark the wires with a ball point pen
Nov 21, 2014 | 1993 Toyota Camry
Free spirit mm2184
see the diagram attached. God bless you
Jul 16, 2013 | Exercise & Fitness
Where does power plug attach to 46" samsung TV
Either on a clearly marked opening on the rear or a few models beneath the ledge where all the rear jacks for the set are(plugs upwards into an opening).
Apr 14, 2012 | Televison & Video
Are the heatsheild on sparkplug wires attached to sparkplug wireboot or attached to head some how I dont want to mess up wires
They usually aren't attached per se, they fit in a socket that is snug enough to hold them. But the spark plug wires trap them into position. So you can go ahead and pull the spark plug wire off.
One thing to remember, when you go to replace the spark plugs you won't be able to see if they are cross thread in their hole, so DO NOT use a socket until you are sure the are properly seated and not cross threaded.
Jun 28, 2011 | 1999 Dodge Dakota
How do i change the spark plugs on a 99 subaru forester?
Subaru Forester Spark plug removal: First, you must remove the air cleaner housing Move the tube from the air cleaner and the intake on top of the engine by loosening the hose clamps at each end. It is still attached to a hose underneath but can be put out of the way
Remove the top of the air cleaner and the filter.
Remove the two 12mm bolts at each side of the bottom.
The side of the bottom is rubber gasketed to the inside fender - just rotate slightly each way to loosen and pull off and put off to the side - there is still a wire attached.
Now pull off the spark plug caps on the side of the engine. This is a boxer engine which means the plugs are in a horizontal position on the sides. It is good to have a pair of spark plug pliers to do this as they are really difficult to remove. (spark plug pliers form a circle on the end when closed and are nice to grasp the caps with). Now you will need a 3/8 drive socket wrench, a 2" extension and a 5/8 deep socket Connect the extension and socket and feed it into the spark plug hole and over the spark plug. It is really deep inside. Now attach the wrench and remove the spark plug making sure you keep the tools level so as not to torque the plug side ways. Once the plug is real loose, unattach the wrench and hand loosen the plug with the extension because the wrench won't fit to remove the extension and socket attached. Remove the extension and socket and then spark plug. Put in the new plug reversing the steps.
Dec 21, 2009 | 1998 Subaru Forester
I want to change the leads on the spark plugs. i
The part that you unscrewed from the spark plug is what allows the plug cap to snap onto the plug. Screw the little adaptor back onto the spark plug - and the plug cap should then snap into place with a little pressure.
Nov 16, 2009 | 1994 Land Rover Discovery
Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Feb 23, 2009 | Dryers
I have the same problem with intermitant power, however, it does not make sense that the problem is in the upper powerhead (which is what a repair guy told me) because-- when I use the other attachements...
You can test the auxiliary plug to the roller/beater attachment with a volt meter if you know how and take precautions. Check for 115-120 volts at the beater/roller attachment plug. If voltage is there and the beater/roller doesn't run, the problem is with the attachment. If not, then the problem is in the power switch or somewhere else that feeds power to the lower attachment.
Feb 23, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
I just bought a palm Z22 PDA. I used the AC charger to charge the Z22 but when I attempted to attach the USB synch cable I noticed that the plug is different from the plug on the AC charger. The USB...
I have concluded that the USB synch cable is not the correct one for my Palm Z22 PDA. There is only one point of attachment on the PDA and it is different from the plug on the USB synch chord. This was the last Palm Z22 PDA in the store so I think that the store clerk rounded up leftover parts and components of previous PDA kits and tried to make a complete set out of it. I am going to return the PDA to the store (Staples) in the next day or two.
Thanks for your offer of help. I will contact you again in the future if I need help.
Oct 15, 2008 | Palm Z22 Handheld
Monster power hts 2000 mkII
Usually the clicking sound is when the unit switches from powering the devices attached and charging the batteries, do the devices attached to the ups still function?
Feb 18, 2007 | Monster Cable PowerCenter HT 1000 (109091)...
Sony DAV-SC8 System Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
