Question about Everex StepNote NC1500 Notebook
My sceen does not power up only the laptop it self
    Guru:
  • 2,178 Answers
Try an external monitor - connect it to the VGA output, enable the external monitor mode, and see if you get a display. If you do, there is a problem in the display - either a bad inverter or the backlight is out if you have a CCFL lamp. If you have an LED (does not use CCFL or inverter) display, the display itself is bad.
Posted on Nov 07, 2010
Will a dell tft turn on with no source
Your monitor should turn on without a source and display the floating 'Dell - self-test Feature Check' message. If it does not, verify the power LED is on "GREEN" and indicating either power on / diagnostics mode or "Amber" power saving mode. If neither indication you have power problems. If these symptoms do not apply, shine a light on the sceen and see if there is a faint image. If this is true, you have backlight problems.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Can i restore my polariod 7 tablet to factory setting without messing up my iphone and laptop files.
Yes, its possible to hard reset your tablet. Turn off the device, hold the power and Volume up buttons together. Once the device turns on release the power button and continue to hold the volume up button. A Sceen with the android service icon will appear. Press the Volume up button once more then you will see a couple of selections. Press the volume down button and select (wipe data/ factory reset) option. be sure to press the power button to select the option. scroll down using the volume keys to (YES- Delete all user data) then press the power button again. Your device will begin to wipe its self. Once the selections appear again select (reboot system now) your device will restart and youll be back to when you first purchased.
Francisco Torres
Wefix Wireless Technician
Wefix Wireless
Aug 14, 2012 | Polaroid 7-in. Internet Tablet - Other
Power LED is green but no BIOS. nothing but black sceen.
Replace cmos battery or use the laptop longer to recharge the cmos battery.
May 21, 2012 | HP Compaq nc4200 Notebook
Laptop sceen black
If everything else is working, hook a spare monitor to the video output, if picture okay! the inverter board just below the screen is more than likely faulty, or the backlight behind the display has failed, but if both show the same symptom it is the video graphics card usually built into the motherboard, I suggest a computer repair shop to address.
May 05, 2012 | Toshiba Computers & Internet
My toshiba laptop was power on but no sceen display,How will i open my computer so that i can view my files?
open your harddisk case it is SATA harddisk so you can attach it any desktop motherboard or external usb hdd drive and backup your file
Feb 01, 2010 | Computers & Internet
Blank sceen
ok
when u power up the computer press F8 key then u see safe mode and other menu then enter in enable vga mode then change screen resolution to 1024*768
May 09, 2009 | Toshiba Qosmio G15-AV501 Notebook
Power but nothing working
It sounds like video card problem. You need a laptop repair shop.
Dec 11, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Nothing Is Workig
This is a normal feature to run thru Self Check to diagnose any issues usually takes about 15 to 30 seconds to go thru process
Oct 09, 2008 | Panasonic DMR-E55 DVD Recorder
Laptop
Most laptops will run without the batteries, its only a few that won't however I do not know for your specific laptop. So its a possibility. Although, the two lights mean that the unit has power so its likely that it doesn't need a battery and the laptop won't boot.
Do you know what the green flashing lights represent?
Jan 16, 2008 | Compaq Armada 1700 Notebook
Dell inspiron 8500
Sounds like the incorrect RAM (SUPPORTS PC2100 AND PC2700 DDR SDRAM SODIMMs) for that laptop. Also try re-seating the RAM in the socket and that is not installed backwards (hard to do , but I've seen it)
Nov 04, 2007 | Dell Inspiron 8500 Notebook
Everex StepNote NC1500 Notebook Logo
57 people viewed this question
Top Everex Computers & Internet Experts
k24674
Alun Cox
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
