It washes but wont despence softener or spin , can make it spin on drain/spin cycle
  • grantwalsh54 Nov 08, 2010
    thanks i did that and it sure needed cleaning ,but while doing that i rememberd that i had been doing some plumbing a week ago ,now this gets embaerrising i turned the cold water off and didnt turne it back on . i didnt notice it becouse the washer would work but not go through a full cycle . my guese is it needs cold water to do the sofener and spin cycle . thangk you very much for your help. grant
  • Washing Mach... Master
  • 8,220 Answers
Oblem:
The detergent and softner dispenser is gravity feed and builds up with "gunk". It has to be cleaned regularly and while the tray is removable, the inlets are not; so you have to fish out the sludge with a paper towel.
Solution:
This common on almost all front load washers.
Remove the dispenser tray. Remove the blue liquid detergent cup. Add all to the top rack of the dishwasher---run a cycle. This makes much less a chore of cleaning the dispenser tray assy.
LG manuals and more wisdom HERE
Posted on Nov 08, 2010
Maytag bravos x econocserve wont go through all the cycles and then you have to select the drain and spin to finish the clothes
You may be over sudsing the machine and it thinks the water is not drain and stops. Run a empty load on a cold water cycle and not hot water. then cut back on the soap. if you use fabric softener the cut back even more.
Feb 01, 2016 | Maytag Washing Machines
When washing machine does not take fabric softener in still left in draw at end of wash
Hi,if you start the cycle again open draw despencer you should hear and see water wooshing inside if nothing then the valve that lets the water through must have packed up or despencer is blocked if you can hear the water clean despencer draw.
hope this was some help
Mar 28, 2015 | Washing Machines
Softener tray is not draining during wash cycle
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Feb 17, 2015 | Kenmore HE3T Washer
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
It seems like our washing cycle goes all the way through to drain/spin without fulling draining or spinning - we have fabric softener left in the dispenser and the clothes are - particularly at the bottom...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | General Electric WJRR4170GWW Top Load...
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Clothes softener does not drain out of the holder
Do your clothes smell funny? Does it take forever for a load to wash? That happened to me and there was a wire loose in the machine somewhere and it would quit mid cycle and never finished a rinse or spin cycle. My fabric softener never drained either!
Oct 03, 2008 | GE Energy Star WCVH6260F Front Load Washer
Maytag Atlantis 7600 spin cycle (top load)
the maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Sep 04, 2007 | Maytag MAV7600 Top Load Washer
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
