Question about Eureka Powerline LiteSpeed 5845 Upright Vacuum
My eueka light speed belt broke.have tried to change it twice the new belts break immediatly and the burning smell ugh! 12 amp
debbily
  • 101 Answers
SOURCE: belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Posted on Oct 16, 2007
SOURCE: Eureka 5197 self propelled bagless upright
ok, i guess it is the motor then because i checked the brush and it turns and the belt seems to be okay now, just loud motor.
thanks for the help!
Posted on Feb 14, 2008
SOURCE: belts breaking frequently
I had the same problem. Broke 2 belts before I got online and noticed this site! What I found was, the roller ends were not turning freely. I had cleaned the hair (nasty) off the roller, but the ends were still not able to spin around without some force.
What I did was, removed the roller and on the 2 ends there are 2 black plastic caps which fit over the bearing, I removed the plastic caps and put a little WD-40 on the bearing, or any industrial lubricant, even new motor oil will work. After putting on the WD-40, I spun the roller end around a few times and the WD-40 lubricated the bearings and Voila! The roller end spun freely!! I put the black caps back onto the bearings on both sides, reinstalled a new belt, it's been working great since.
It saves the cost of a new roller.
Todd M, Fremont CA
Posted on Mar 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Posted on Apr 15, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
I have Hoover Widepath Bagless 12 Amp Windtunnel vacuum. Yesterday I was vacuuming and smelled smoke and it shut itself off. Today I cleaned out the filters (they weren't bad) made sure nothing was...
Hi There,
When a vacuum cleaner smokes, it is usually only one of two possible problems.
It could either be that your motor burned up, or that your belts burned. The belts on this particular model are notorious for breaking, but the fact that your machine doesn't come on at all after this happened, sounds like it may be the motor.
Both of these issues have a unique smelling smoke. If the smoke smelled like an electrical burning smell, this indicates it's your motor. If the smoke smelled more like burning rubber, then it's probably your belts.
If the smoke smelled like burning rubber, here's a video that we've recorded showing step by step how to inspect, trouble shoot, and replace the belts on your vacuum cleaner. If you open it up and the belts are still in tact, then this probably is a more serious problem of the motor burning out.
. I'd be more then happy to walk you through more advanced diagnosing if this doesn't fix your problem, please just use the comment box here on the Fixya repair page.
If this was helpful to you, please be so kind and rate my repair helpful, or leave some feedback for me. This is really appreciated by the Fixya community if the repair solution was able to fix your problem.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Self-Propelled WindTunnel Bagless...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Aug 19, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Belts
Recently received a kirby from mother in law and don't how to change the belts
Dec 15, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Eureka Powerline LiteSpeed 5845 Upright Vacuum Logo
144 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
