Question about Ademco CIA Modem
I have completely lost the master code for my alatm system. is there anyway to override and reset a new code?
Security unlocking code
You need to specify the Phone brand,model,Country and current network name to get exact answer. Anyway,Try out the default codes like 12345 or 0000 or 1111 .If those doesn't work use Master reset code. A master reset code is a code that completely resets your phone, removing any security locks(except network locks). You can get the master reset code for free for some old model Nokia and Alcatel mobile phone from Unlocking4Free.com .
Jul 03, 2013 | Nokia Cell Phones
I lost my security code in my mobile i cant open the code plz
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site http://www.unlock-free.com/nokia-master/ , it has the best services for the master reset code for your Nokia 6030 model mobile.....I hope that it may helpful to you....
Dec 13, 2011 | Nokia 6030 Cellular Phone
I've lost my imei and i've forgotten my security code dont know what should i do?
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site Onlinegsmunlock.com, it has the best services for the master reset code for your Nokia 3110 model mobile.....I hope that it may helpful to you....
Aug 03, 2011 | Nokia 3110 Cellular Phone
How do i override a forgotten password
If you forget the security code means, you can get the master reset code for that one,
What is your mobile and model?
If you have the nokia mobile means, get the master reset code here http://www.wickedunlock.com/nokia-dct-master-code-service/rs11wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones.........
Apr 26, 2011 | Cell Phones
Lost my security code for 7610 nokia
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site Unlocking4free.com , it has the best services for the master reset code for your Nokia 7210 model mobile.....I hope that it may helpful to you....
Mar 22, 2011 | Nokia 7610
Hello I have a simon 3 and need to reset the master code, I dont have the old code. What can I do to start using the system again
You can change the master code only if you have the installer code. If you don't have the installer code, the only way I know of to reset the master code is to reset it to factory defaults. This does mean that you will have to completely re-progam the system. I would document as much stuff as you can from the display before resetting it. If you don't have a copy of the installation manual I am providing a link below. Hope this helps.
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 21, 2010 | GE Security Simon 3 Wireless Home Security...
LG LKD 8D/S model System reset ??
DO NOT DO A RESET, you will loss all of your programming. get me the model of the vodavi, and I will get you the default password of find out how to reset it without resetting the system
Mar 01, 2010 | Vodavi 30-Button XTS Telephone
Can i override my security code
Yes, just enter the code 10 times false, then your phone will reset himself and let you set new one.
Don't forget : all your data will be lost.
Jan 23, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I can't power on my mobile(Nokia 6708) because of startup security lock
Hi i can give you the master override code that gives you acess to the phone and resets the code to what it was when new usually 1234 or 12345 or 0000 depending on network but the code im giving you will only work with your imei number and will also only work if the code hasnt been entered wrong more than five times enter this code when you switch phone on and its asking for code.
If you have entered more than 5 goes at getting the code and you got it wrong more than 5 times then this code wont work and the only way to unlock it is using flash lead and unlocking software the problem with this is that alot of new nokias cant be reset after the code has been wrong 5 times they done this so stolen mobiles couldnt be used again.
Anyway here is the master override code you need
make sure you have given me right imei number but if you have the code for that imei number is 6 2 4 4 3 4 3 5 5 7
Let me know how you get on and also if you need further assistance ok
Feb 08, 2008 | Nokia 6708 Cellular Phone
Magnavox 27MS343S 27" TV
You will for sure need to borrow a remote from someone to do this. But I will give you the way to unlockit just in case you can get one. Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Aug 30, 2007 | Philips Magnavox 27MS343S 27" TV
Ademco CIA Modem Logo
42 people viewed this question
Top Ademco Computers & Internet Experts
David Payne
David Payne
Are you an Ademco Computer and Internet Expert? Answer questions, earn points and help others
