Question about Mongoose Exile 26 Men's Full-Suspension Mountain Bike
How do you raise the handle bars on a mongoose scorch bike?
    Scholar:
  • 71 Answers
There should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Posted on Nov 09, 2010
Raise the handle bars on my new mongoose bike
in the middle of handlebars you will see a hexadon bolt,when you got your new bike the right angle wrench should have been with it if so place the wreanch onto the bolt and turn anticlockwise this will loosen the nut,then pull the handlebars up until the wright is achived make sure they are straight then turn the wrench clockwise until it tightens,.Adrian....
Jan 23, 2015 | Mongoose Cycling
The handle bar stem on my sons mongoose is loose. I have tried to tighten the screw that connects to the stem but it doesnt seem to be stopping the bars from being shaky?
Your handle bars are most likely stripped or the mongoose head is stripped or a combination of both. Unscrew the bolt you just tightened and take the handle bars off to inspect the little splined area, if smooth than handle bars need to be replaced. The neck should also have those little lines horizontally this area should not be smooth. You can try to wirebrush the area and out it back together, see if that works or the cheapest thing to replace would be the handle bars. When I was a kid I would pin my handle bars so they would not move cause we did a lot of jumping of our bikes and had a lot of stripped handle bars. Mongoose is a good stem I would lean towards new bars. Good Luck...
Aug 16, 2011 | Cycling
How do i raise the handle bars on my grand daughters mongoose 7sp amethyst bike
I just did a search for this bike--
Did you get it at Walmart?--
Did you ask the salesperson there to help with this problem?
From what I can see, from the pictures that came from my search-
I do not see that you can hope to raise the handlebars very much!
This is not a very comfortable bike to ride--
Maybe you are trying to get something from this bike, that it was not designed to produce.
Let me know what you have tried so far-
Mack B
Jul 04, 2011 | Cycling
How do I raise the handle bars on my mongoose xr 200 21 speed bike
Your handle bar stem has a metric screw in the the neck of the bicycle. But, a word of caution, do not raise your handle bars more than the safety mark on the stem, it has to be inserted that much or it and it can snap in two and result in serious injury. Take it to a bike shop and they can either show you how or advise you on replacing the stem with a longer one. This is a very important part on your bike, do not take chances.
Apr 05, 2011 | Cycling
I want to raise the handle bars on my Mongoose XR75 mountain bike, any ideas
Be careful, the stem must be inserted at least 3" or to the safety line, or it will snap off. You have to have a metric allen wrench. Like I say, and I cannot stress it more, do not raise beyond the safety line on stem, buy a longer stem, if you want it higher than that. If, the bike is too small, buy a bike that fits you from a shop who specializes in sizing.
Sep 16, 2010 | Cycling
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Apr 04, 2010 | Mongoose MGX Maxim Dual Suspension...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
496 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
