Question about GE Profile DPSR473EW Dryer
Will no stay on or spin - GE Profile DPSR473EW Dryer
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Shows booting but just stays there does nothing shows asus screen and spinning circle and stays there
Hello There,
You have not mentioned which operating system are you using i.e. win 7, win 8 or win 10.
First need to understand that you see a spinning circle at which stage, what do you see behind spinning circle, blue screen or black screen or windows logo.
Try to follow below steps hope that help you to fix the issue:-
https://www.easeus.com/todo-backup-resource/fix-windows-10-stuck-at-login-screen-with-spinning-circle.html
If this does not help then revert back.
Regards,
Sunil
Jan 28, 2018 | ASUS Computers & Internet
Gives you the error code for the spinning does not work
If you have the error code # you will find it on the net.
Sep 09, 2015 | Washing Machines
Will not spin at all & clothes all stay wet??
motor brushes failed will need replacement cheap to replace.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
Brakes seize up and stay on after driving for a distance, especially in hot weather. They release when cooled down. Is this the master cylinder or calipers? Car is in good shape at 100 K. Garage kept all...
Jack car up, spin wheel, then apply brakes, and release and try spinning wheel again. If it doesn't spin just as easy, try cracking bleeder screw open, then try spinning wheel. If it spins easy after you crack bleeder screw, tighten bleeder back up & try same again. If same result, wheel spins when bleeder opened, then I'd replace the 2 front flex hoses that attach to calipers. If caliper doesn't release then you need to pull calipers and check if partially seized, or maybe slide pins that caliper moves on (that attach caliper to spindle) need cleaning and lube applied to allow calipers to move back & forth.
Aug 11, 2009 | 1985 Plymouth Reliant
Hotpoint WMA50 won't final spin, and water stays in drum
Running with a restricted water supply probably took out the pump.
The stator requires a steady water supply for cooling and lubrication. Without this accelerated wear between the stator & magnetic poles occurs.
This additional clearance makes the magnetism insufficient to spun the impellor.
Oct 17, 2017 | Hotpoint WMA50 Front Load Washer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
