Question about HP LaserJet 1020 Printer
I have an HP1020 on a IMAC. Makes an aweful sound after turning on the power. When printing, the papers dont come out totally, it stops. The black ink spears on the page. Just updated the drivers. Should I bring this in to get it fixed or throw it away. Is it fixable.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Toner cartridge may be deffective. If new cartidge is around USD 100 in your'e region, I suggest getting a new printer
Posted on Nov 07, 2010
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro....
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
May 23, 2011 | HP LaserJet 1020 Printer
Copies made are totally black. what do i do? i changed cartridged, put in new paper then copied. it copied fine after 20pages, copy sounded like it was jamming up, paper came out with some parts black....
Hello limay_uera
Please check your Printer setup. or options ( I am not familiar with this printer. what terms they use- I'm not sure) Ther will be options for Print in Color or Black. Make sure the radio button for COLOR is checked. This way, black and color both will print in the correct color. So leave it on color even when you want to print in Black. The black radio button is there for a different reason.
Hope this will help you.
luciana44
Nov 19, 2009 | Canon FAX-L800 Plain Paper Laser
Printer will not print out anything
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please disconnect and then reconnect the power supply on the printer and make sure it makes a setup noise when the cable is reattached. Will the printer perform a form feed with paper loaded when the gray button is pressed?
Next, try this printer self-test by following the steps given below:
1. Turn the printer's "Power" off (metal button).
2. Press and hold the "Paper Feed" (gray) button.
3. While holding the "Paper Feed" button down turn the "Power" button on and hold both buttons until the power light comes on 5-7 seconds.
4. Release both "Power" and "Paper Feed" buttons.
5. The printer should feed a sheet of paper in and print a test page.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
However, please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
May 21, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark z2320 printer
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below: 1. Turn off the printer.
2. Press and hold the power button for at least 5 seconds, then release the power button.
3. The Self-Test will print. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridge installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without the cartridge installed, run the self-test again with only a color cartridge installed. If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 12, 2009 | Lexmark X2550 All-In-One Printer
Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
Apr 11, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Mar 06, 2008 | Lexmark Color JetPrinter Z23 InkJet
Linksys Psus4 printserver for usb with 4 port which i'm using to connect my hp1020 printer on the network ???
Hi please go through this link
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&rule=43040&docname=c00384459
Nov 16, 2007 | Linksys USB200M USB 2.0 Network Adapter
Paper will not feed into printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
HP LaserJet 1020 Printer Logo
47 people viewed this question
Clive
Clive
