Question about Kitchen Ranges
Shattered glass top for Hotpoint range/ how to replace
This top was shattered and we have a replacement, but there are no instructions on how to install this. HELP What are the directions for replacing the glass ceramic cooktop? Is there a schematic? Thanks!
    Genius:
  • 1,036 Answers
Hi there!
There are two basic types, Flush fitting and framed.
The framed versions are a bit like a picture frame, with the fixings around the edge and back. The flush ones rely on adhesives to the base edge around the plate, but may have a metal fixing frame attatched already.
Check the new plate you have to see if there are any keyhole shaped slots on a subframe (indicating a drop on, and push forward to lock arrangement) or if it looks different to the one that is broken.
The old saying - "If in doubt- ask" is true here, and you should telephone the manufacturer for any specific fitting instructions. You may need additional parts - fixing plates, screws, seals or adhesives, so I would advise calling their service department to ask if additional parts are required for fitting.They should be happy to supply them if needed.
This is not a cheap item, so don't risk poor fitting or damage by lack of correct parts.
Posted on Jun 15, 2008
How do I remove grill/top oven door of a concept c362e as glass has shattered
most oven doors just lift off the hinge when about 1/3 open for cleaning purposes.any good glass shop should be able to replace it for you if wanting to.
Jan 05, 2015 | Kitchen Ranges
Can my oven still be used if the outside glass is shattered
No!!!
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 12, 2010 | Whirlpool GS460 Gas Kitchen Range
The outer glass on my hotpoint oven door has shattered do i need special replacement glass
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Nov 11, 2010 | Hotpoint DY46 Style Line Stainless Steel...
The outer glass on the dooor has shattered, where
Try this link. Price is $92.00. I have replaced some of these and they are not hard to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=250474&diagram_id=98440#d98440
Jan 05, 2010 | Whirlpool GR399LXHS Electric Kitchen Range
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Glass stove top shattered
yes it can be repaced but they are not cheap may costv a few hunderd dollars thanks from gilles
Mar 15, 2009 | Frigidaire FEF366 Electric Kitchen Range
Need to replace the glass top on a ge hotpoint stove
If you require instructions on how to replace a glass cooktop, the following link explains how:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
Let me know if you require addtional assistance. I hope this helps you.
Aug 17, 2008 | Hotpoint Kitchen Ranges
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off. Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier. If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them. Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Sep 07, 2007 | Kitchen Ranges
Kitchen Ranges Logo
403 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
