Question about JVC Video Cameras
I have a mini jvc digital video camcorder. All of a sudden the Menu button and the button you press to take a still picture won't work? I had left it outside in my car over two nights. It was fairly cool out. When I brought the camera back it there was condensation on it when I took it out of the case. It has sat in the house for over 8 hours now and the battery is fully charged but it still won't work. Any suggestions?
    Novelist:
  • 58 Answers
Depending on which model of camcorder you have, it can take far longer than 8 hours to get itself warmed properly inside.
If possible, open any slots it has on it (tape and memory card slots etc.), and take the battery out/off - leave any battery compartment door open too. And leave it in a standard temperature room for about half a day. A memory card type camcorder should take less time than a Mini-DV or DVD model, but the time to 'defrost' can vary a lot from one model to another.
Don't leave it near to a heat source (like a room radiator) to warm if faster, as it has to do it naturally over time. Most DVD and Mini-DV types will give some kind of indication about condensation being a problem though - a warning light may show, or a message saying *DEW* or *CONDENSATION* may appear.
If other buttons seem to work, but just not the ones you mentioned, then it may be they have damp behind them. This may dry out over time again, but also sometimes the tiny buttons need to be cleaned off inside. Not a simple task as the item would need taking apart just to be wiped inside the buttons/contacts.
Hope that helps a little.
Posted on Nov 07, 2010
Shooting in black and white --i don't know what is the problem --need help
1. Set the Power switch to CAMERA.
2. Set the Mode switch to TAPE. (VP-D353(i)/D354(i)/D355(i) only)
3. Press the MENU button.
4. Move the Menu selector to the left or right to select Camera, then press the Menu selector.
5. Move the Menu selector to the left or right to select Digital Effect, then press the Menu selector.
6. Move the Menu selector to the left or right to select the desired Digital Effect mode, then press the Menu selector.
7. To exit, press the MENU button.
Feb 18, 2011 | Samsung SC-D353 Mini DV Digital Camcorder
Cannot record due to a black screen
OK, that means you can see clear picture in playback of old recorded tapes and camcorder just wont give you live view to record any more.
If its true then it is known problem/ failure of ccd imager in your JVC GR-D33 camcorder.
JVC will repair it free of cost, click JVC CCD Imager Advisory for details.
Thanks.
Sep 17, 2009 | JVC GR-D33US Mini DV Digital Camcorder
I carnt find the button to start recording
  1. set it to "A" position
  2. then when your right hand is holding the camera correctly reach up with your thumb, and press the button.
  3. it looks like a power/charge button
Apr 16, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
JVC Picuture gets blurry
The ccd block is starting to fail. Thats the chip thats the eye of the camcorder at the back of the lense assy. Its mounted on a small circuit board. You can find the chip at parts.com. Its just a matter of dissassembling the camcorder and removing the chip from the board and soldering another onto it taking care not to over heat the chip. You do need good soldering skills.
Tim
Aug 24, 2008 | JVC GR-D22U Camcorder
Where is menu on switch
According to the manual, the Menu button is on the rear of the camcorder, just below the battery. Pressing this button activates the menu, and using the dial on the lower left side of the camcorder allows scrolling and selection (press the dial in) of menu items.
Jul 30, 2008 | Canon ZR100 Mini DV Digital Camcorder
Deleting unwanted files with a JVC Everio MG130 Camera
Answer:what you do is you press the play/record button on the left side of the camcorder when it is open to get to the videos. then you use the laser touch operation to scroll to the video you want to delete. then, right under the screen there should be 5 buttons. the one to the left of the menu button has a picture of a garbage can looking thing above it. just press that and then press yes when it asks you if your sure.
Jun 30, 2008 | JVC Everio GZ-MG130 Camcorder
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Playing MPEG's
* The MPEG Playback function works in M. PLAY mode only. * You can play moving picture images on the Memory Card. * To hear sound during MPEG4 playback, you must hook up to a PC and listen to the PC's speaker. (You cannot hear it from the speaker on the camcorder or a TV) 1. Set the mode switch to MEMORY CARD position. 2. Set the power switch to PLAYER mode. 3. Press the MENU button and turn the MENU DIAL to highlight MEMORY. 4. Press the ENTER button to enter sub-menu. 5. Use the MENU DIAL to select MPEG4 from the sub-menu. (M. PLAY SELECT) 6. To exit the menu, push the MENU button. 7. Using the (FWD) and (REV) buttons, search for the moving picture that you want to playback. 8. Press the PLAY/STILL button. The moving pictures recorded on the MEMORY CARD begin playing back.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
50 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
