Question about Dryers
The dryer is doing the tumbling and blows air but no heat. So clothes do not dry. How do I fix this? Feels like fuse or a thermostat issue somewhere in the dryer.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
Dryer tumbles,blows cold air no heat,looking for access to fuses,dont know what part of dryer fuses are located
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
I have a Lady Kenmore electric dryer (40 years old maybe?), model 110 6508923, which I cleaned the vents, strong air, tumbles fine. The heating element glows orange for a few moments, then as it finally...
The element is supposed to cycle on and off thru out the drying cycle as not to burn clothes. Is it just taking too long to dry. If it is your exhaust from the wall behind the dryer to the outside is clogged somehow. I like to use a leaf blower stuck inside the exhaust behind the dryer and blow the whole line out to the outside of the home.
Jan 31, 2010 | Dryers
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Not drying clothes
If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
