Question about Nordic Track NordicTrack Treadmill, A2550
I have a nordictrack a2250 when run on it the belt slips i need to tighten the belt
  • 20 Answers
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
Posted on Nov 09, 2010
Why does motor run about one second, then shuts down?
If you wish to get some details; check the site linked here. Pull up older posts. Surf for article abort treadmill.
http://electro-medical.blogspot.com/
Jan 14, 2016 | Nordic Track Nordictrack A2250 Treadmill...
The light on my panel is very dim. Does it require battery replacement? if so where are the batteries located on this model?
There is a manual here which doesn't mention a battery, but I am sure I see what looks like a battery cover with a single screw under the console. I also see other posts which state 'lift the console and replace with fresh batteries'.
PDF]View Manual in PDF Format - NordicTrack https://service.nordictrack.com/CustomerService/pdfDownload.do?... this manual and order part number 146148, or ... tem is damaged, the walking belt may change speed ... ercising, the unique A2250 treadmill can be folded up,.
Dec 28, 2015 | Nordic Track Nordictrack A2250 Console For...
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
Jun 17, 2012 | Nordic Track NordicTrack Treadmill, A2550
The resistance belt on my nordictrack 1300 woulnt tighten. How do I fix it? Thanks for you assistance.
When using the NordicTrack in manualmode, you can adjust its resistance by twisting a resistance knob, locatedeither in the corner of the console or on the upright support. If the treadmillbelt slips from side to side, you need to adjust its tension via bolts locatedin the back of the machine frame. First find the treadmill adjustmentbolts in the rear end of the treadmill frame, to either side of the belt. Now putin an Allen wrench into each bolt, one at a time, and turn each bolt aquarter-turn clockwise. Slip one hand among the belt and the treadmill deck. Ifthis doesn't pull the treadmill belt taut, it's still too loose. Tighten thebolts another quarter-turn. Continue testing the belt tension, then adjustingthe bolts as needed, until the belt is just loose enough for you to slip yourhand between it and the deck with no extra slack. Step onto the treadmill andwalk. The belt shouldn't bind or slip side to side. If it does, dismount andre-adjust the bolts until the belt tracks correctly. AV
Jun 11, 2011 | Exercise & Fitness
Just bought a Nordictrack a2550 last week. Only used it for about 2 hours and I'm having bet issues already. The belt will not stay centered no matter how much I try to fix it. The belt is also slipping...
Do you know if you are tightening it correctly?
Both bolts at the back of the walking belt should be turned clockwise to tighten the belt. You must also tighten the bolts the same amount and typically no more than 1/2 turns at a time. I usually adjust belts while the machine is running at approx 3 mph. Your belt should be just tight enough to not slip when you walk on it. If its too tight you'll wear out the motor bearings.
Feb 10, 2011 | Nordic Track NordicTrack A2550 PRO...
I have a NordicTrack Elite zi treadmill. While running I hear a ratcheting click coming from the front housing area. When I hear this ratcheting click the belt is slipping a little bit. Any ideas of...
This is more than likely a loose drive belt, which would explain the slipping as well as the sound. To tighten this take off the plastic cover that covers the motor. You will see where the motor connects to the front roller with the drive belt. To tighten it there are two bolts that hold the motor to the machine, loosen those then pull it tight and retighten them, This should eliminate the problem.
Aug 17, 2010 | Nordic Track NordicTrack Elite zi...
I have a NordicTrack A2250, about 2 years old. When it's turned on, the control panel lights up, and when I insert a program chip, the console "speaks". However, the neither the incline nor the belt...
Will the treadmill work when the chip is not plugged in, or does it just beep every time you select a button? If so, your problem is easy to solve. The board that supports the two adjacent up and down buttons has slipped. To fix, you'll need to remove the panel and remove the 3-inch retaining bar which is held in my two screws. Realign the board so the buttons are free to move in the available slots. Good luck.
Dec 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
499 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
