Question about Dryers
The dryer is making a lot of thumping noise - Dryers
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 11, 2010
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Dryer makes lots of noise when drying..squeaky ans sometimes a "thump"
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 07, 2010 | Kenmore 64882 Electric Dryer
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Kenmore 84052 Dryer
Did you resolve your dryer / noise?
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
My dryer -model FER311F makes a thumping noise while in use.
Check the 4 feet & make sure top of of appliance is level. These 4 feet will have threaded adjustments, just tilt the dryer back and should be able to turn with your hand or may require pliers, good luck.
Jan 21, 2009 | Frigidaire FEQ332E Electric Dryer
Open Questions:
Frigidaire faqe7011lw0 dryer having issues, not heating up and shuts off after 10 minutes My dryer model number is faqe7011lw0. It seems to start up, and then after about 10 minutes, consistently, it shuts off and has a bunch of blinking lights on the right side of the control panel. It started off with an error code of E4A which states "The drying time has exceeded program time for that cycle". I got that code to go away and then i got another code of "E4B" which states "Temperature reading of control thermistor has not changed in a certain amount of time". The second error code makes more sense because I notice in the 10 minutes that it runs, there seems to be no heat, so i feel something is causing the dryer to not heat up. The troubleshooting for this states to test a relay on the control panel, but I wanted to see if anyone else had this issue before. The weird thing about this is, if I run the dryer empty, the cycle completes the whole way through, but with wet clothes, it shuts off exactly at 10 minutes, no matter what cycle i set it to. I thought maybe this was a sign I had too large of a load in, so I took out about half the clothes, and ran it then. I still got the same issue. So I am kind of confused why when I run it empty, I get the full cycle with no error code, but with anything in the dryer at all, it stops after 10 minutes and gives me an error code. FYI, I have check the exhaust too to make sure it isn't clogged with lint, and it is wide open.
Mar 18, 2019 | Frigidaire Dryers
Dryers Logo
66 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
