My nordmende nu323ld built in digital is not working i can select DVT on the source pannel and it comes up in a blue box " DTV INISTIALISING" and then goes to a black screen. when i press the dtv menu on the control it does nothing. CAN ANY 1 HELP :)
SOURCE: Digital Tv is stuck on a channel
I have found the solution at last :)
Put the TV in standby and press these buttons in order
Info, Menu, Mute and Power on.
You will then see a hidden menu, on line 12 select reset
Bingo :)
Posted on Dec 30, 2007
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
SOURCE: built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Posted on Dec 25, 2008
SOURCE: magnavox dtv converter
my convertor box stopped displaying the green light and i cannot get it to come back on ......i have replaced with new batteries
Posted on Jan 16, 2009
SOURCE: need help
ensure the tv is in analogue mode, not dtv and turn it off. with the remote: press info then, menu, then mute then power. these buttons need to be pressed sequentially not all at the same time and in quick succession. a menu will appear on the tv. navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button) the tv will reset itself and turn off. turn the tv back on & it'll re tune all its channels. DTV should be working again.
Posted on Mar 28, 2009
How do I watch normal tv on my audiosonic television ?
That depends upon which source your "normal" TV is connected. If you have a cable box using a coax cable, then you will either select the DTV source if the cable box uses digital output or a digital over-the-air antenna, and ATV source if the box is using analog signals or if you are using an analog over-the-airwaves antenna. If you are using a cable box but have an HDMI cable connecting it to the set, then you need to choose HDMI1 or 2 as appropriate. If you have a box that uses the red-black-yellow RCA cables, then select the AV input. Remember that for ATV and DTV inputs from a cable box, you usually have to tune the set to either channel 3 or 4 and use the box to change the channels.
Jan 05, 2016 | Televison & Video
Is this model digital or do I need a top box set
Ian a model number and the make / Manufacturer would be helpful
If you use the select source on the remote control if it displays DTV as a source then it should do digital once you tune the television in - you may have a channel autoscan option in the menu options most likely and you may even see it scan for DTV channels !
Dec 11, 2014 | Televison & Video
How do I change from Digital to Analog TV?
source mode,(button on tv usually next to menu) tv menu ( usually first page at top of screen), . or tv/dtv on remote ( some times just say DVT on it but you press it twice to go analog ) it all depends on your tv, also depends if the system on the tv has been updated some tv's when the change over happens, remove analog settings so there is no analog on the tv just digital. you can buy an analog box that will fit to the av socket or just connect a old video to the scart socket and get analog that way.
Sep 14, 2013 | Coby TF-TV3217 32 in. LCD TV
I cant get the programme up and down to work and wonder if its in txt mode but i dont know how to change to dtv mode
the two are usually not related---text is a mode for either captions or a black box on the screen and I presume you mean dtv not tvt.
Aug 27, 2012 | Alba LDVD1538WDCH LCD TV
My mum in law aged 94 has now got a Logik l19dvdb20 (had to becuase of digital change over) its her only view to the world. I have tried a few easy to use so called universal controllers but they dont work...
Unfortunately there is nothing in the menus to allow for the requests. Maybe a way around it is to write down, on a piece of white card, which button to press "parrot fashion" to get the desired result that she requires.
Hope that helps.
Jan 02, 2011 | Televison & Video
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Sep 29, 2009 | Samsung Televison & Video
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Does Toshiba TiVo RS-TX20 accept the digital in February?
Any DTV Converter Box.
You Need a IR cable to control the DTV Box from the Tivo.
Repeat Guided Setup and select the correct DTV Box on the setup.
Jan 03, 2009 | Toshiba RS-TX20
Is DTV converter box compatible with this set
how do u get cable ? now who form direct from wall cox cable charter or dish ?
Oct 08, 2008 | Durabrand DWT1304 13" TV
Is it DVT ready?
You have an analog TV. If you are asking for the purpose of getting a DTV converter box, you only need it if you use antenna for signal. If you have cable or Satillite there is not need for the coverter box.
Jun 05, 2008 | Philips 20PT653R 20" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
