Question about Hunter Fan Company 7-day programmable thermostat
Hunter 44660 Programmable Thermostat - error 005 when attempting to override current temp settings
rizla
  • 1463 Answers
SOURCE: How do you set the thermostat??
hi
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
riz.
Posted on Feb 26, 2008
SOURCE: hunter 44360 thermostat wiring
LOL I'm having the same problem with the same 44360.
Posted on May 03, 2008
SOURCE: Thermostat
By resetting I found out that there was low battery, but now I can't get the face of the thermostat off to put in a new battery. Manual got displaced.
Posted on Jul 21, 2008
I bought the hunter 44360 programmable thermostat also, and have the same problem with the heat not shutting off. I recently took off the face plate and started looking at the switchess on the back. Look for a switch that has the option "std" or "hp". I flipped the switch to the "std" position and my therrmostat has been working great in heating my home.
hope this helps,
rich
Posted on Nov 18, 2008
VtToolMan
  • 704 Answers
SOURCE: thermostat takes too long to cool down 1 degree
Thermostats don't cool or heat. They are just the control device that tells the furnance or AC to operate and register the present temperature and tell the furnance or A/C to shut off, once the desired temperature has been reached.
Most programmable thermostats will take at least 1-2 weeks to "learn" how long to run the furnance or A/C in order to reach the desired temperatures you've programmed into it, for the time you want it be that temperature. Variables such as extremely hot days and higher humidity will also affect your cooling system.
Give it a little time to self-learn and it should adjust itself after a week or two of operation. You might want to take some time to review and familiarize yourself with the owners manual to see what Hunter advises for setting up and using the thermostat.
You may need to have your A/C checked to see if you're running low on freon, or need to have the coils cleaned, need to change the air filter, etc.
Hope this helps and best regards!
Posted on Aug 01, 2009
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
Regardless what I do I can not reset the change Filter message and this is a problem on both of my 44660 thermostats. I followed the proceedure in the manual.
I have a solution!!!! Ok, hit the filter key. You will see the filter counter screen. Hit and hold the RET/CLEAR key until the Filter flashes and it clears the counter. I just found it by trial and error. I wrote it inside the cover so I could remember.
Oct 03, 2010 | Hunter Fan Company 5/1/1 Programmable...
I reset my hunter thermostate and now its showing Celcius instade of Ferienheit temperatures, how can I change it back?
Press and hold for about 1 second to enter Manual Override mode. When display flashes, you can release the key. ■ Press again to change to your desired Set Temperature. Hold the key for 2 seconds to fast-advance the Set Temperature. ■ Press to return to normal mode, or wait 5 seconds for it to return automatically. ■ The current program number will flash to signify the Temporary Override. ■ At the next program change time, the Temporary Override is cancelled, and the next program temperature becomes the setpoint temperature. To end the Temporary Manual Override: ■ Press and wait for HOLD to display on the LCD. ■ Press again. This will return the set temperature to the current program set temperature.
Apr 28, 2010 | Hunter Fan Company 7-day programmable...
Basically, your going to press either of the arrows until it flashes, or about 1 second.
Then you set the temperature you desire and then press and hold the HOLD button until HOLD is displayed in the display.
Congrats, your on a permanent hold.
Then your next step would be to go get a real thermostat, install it on the wall, and then throw that piece of **** Hunter out the window as hard as you can.
The biggest problem with the Hunter stats is that they are cheap. On top of that, the programmable stats have a factory set program that cannot be simply deleted. Its always there, no matter what you do. And it makes for hassles when it goes back to factory settings and you either have to painstakingly re-program it or deal with the factory settings.
Here is a link to the Hunter manual.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/43153.pdf
I would recommend to you the Honeywell line-up. The Visionpro 8000 series is a very nice and user friendly thermostat. Its the same one I have on my wall. Very easy to use and understand. Its touchscreen and the screen can be locked to avoid unwanted use of the system.
Jan 14, 2010 | Heating & Cooling
White-Rodgers 1F58-58 to Hunter 44660
This is the corrcet wiring:
G - G fan relay
R - RC1, RC put a jumper RH ( to supply power to the cool and heat)
L - no wire connected (malfunction indicator) tape- off that wire
E - Emergency heat relay
B - W/B ( reversing valve in your heat pump energized during heat )
W2 - Auxilliary heat
Y - Y1 ( compressor contact)
O- Y/O ( reversing valve is energized during cool)
make sure that the system selector is on heat pump position.
Apr 30, 2009 | Hunter Fan Company 5/1/1 Programmable...
hi
riz.
Feb 26, 2008 | Hunter Fan Company 5/1/1 Programmable...
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 7-day programmable thermostat Logo
78 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
