Question about RIM BlackBerry? Curve 8330 Cellular Phone
I think that my blackberry cuve may have a little bit of water damage because someone spilled a drink on it last night. I took the battery out and put it back in and the phone comes on and the messages are still coming in but none of the buttons work. the scroll ball will scroll but when u press it nothing happens and none of the other buttons do anything either. i tried just using a blow dryer to dry it but that didnt seem to help. what can i do aside from having to buy an all new phone?
    Problem Solver:
  • 5 Answers
First, to check if there is water damage inside the phone, you can check the water mark sticker.
When you take the back piece off your phone, on the left of the battery inside a rectangle shaped cut-out in the plastic, you will see a little square. If it is red/pink this means there is definitely water damage, if its white then no water has reached that part of your phone. Unfortunately if its turned red or pink Blackberry will not repair it free of charge.
That being said, you can try completely submerging your phone in a bowl of rice. This will draw the moisture out and hopefully get your phone in working condition again, this has worked for myself and many friends.
Posted on Nov 08, 2010
My Acer Chromebook wont turn on after a water spill
Power IC maybe damaged by water, try opening the whole system and dry the circuits and body and reassemble and try again, and well last option is always service center..
Mar 19, 2015 | Acer C720 11.6" Chromebook - 2GB Memory -...
Water damage .....
best to clean with 100% alcohol. let it set for a long period ive done it and it has worked many times but turning it on will ruin it if there is any moisture in it. i set mine next to my heater for about 3=4 days your keyboard will most like be shot they go first but if you cant afford a replacement get a cheap regular keyboard and plug it into lappy and thry work fine same with a mouse.remove battery of course.
Sep 13, 2012 | ASUS UL30A X7 1.3 GHz 320GB 13.3 inch...
I have a nokia c5 mobile, everytime i'm on the phone to someone the volume during the call is very low though the volume is maxed out. This did not happen before.
If you spilled water or any drinks or liquid on your cell phone, or if it was in the bathroom while you were taking a shower, it is possible that the audio is damaged. I spilled a little bit of water on my cell phone and had the same problem.
Jul 24, 2011 | Cell Phones
When someone calls my i phone I cannot hear them through the reciever. I can only hear them if I turn on the speaker phone. What should I do to reolve this problem?
ore than likely there is some dirt or even a little bit of water in the jack, which is what happen to me when i spill my drink on my precious, but nonetheless that's a simple if it was only a little bit. all you need to do is go to a local store and pick up a can of compressed air a spray a bit in the jack and try it out, it should work if it goes out again repeat i had to do this a couple of times but it works.
Nov 26, 2010 | Apple iPhone 3G
Little water got spilled tried keys later they worked now hey dnt
It will continue to get worse and do a number of things. Moisture is really bad on dc pcb's. After it dries it will start to corrode. The best thing is do a full break down and remove and signs of corrosion. You may need to order a new keyboard. The long beep could indicate problems with either your ram or hard drive.
Oct 22, 2009 | Acer Aspire One AOA110-1113 Netbook
Can get blacberry tour to power up
You may have gotten the battery wet - either through direct contact with liquid or condensation. Open the back cover and check to see if the little white sticker has turned pinkesh/red.
Sep 13, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Icemaker wont dispense water. worked last night but not today.
without knowing model #, i would check to see if the unit has a resevior for drinking water in the fridge side, could be something as simple as the temp set too low in fridge side and freezing the res. check that out. or it could be that your water valve in the back is faulty. take the hose off in back and have someone push the dispenser lever in the front. if it squirts your valve is good and you probably have somekind of blockage in the plastic tubing somewhere. solid 12 gauge wire works great for that. just run it in the tubing but be careful, you dont want to damage it. good luck.
Mar 20, 2009 | GE Refrigerators
Water spill on my AOC2216Vw LCD Monitor
Hey man, thanks for coming to me. Um yea, massaging may help but too hard will do damage since it is LCD is Liquid Crystal Display and it is fragile and easy to damage. The water should clear up in a few months, if not i would look at replacing it which can be costly. Here is a link to fix your unstuck pixels
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor]
Now im not liking that bit about how you mentioned was spreading so leave it for about two days, give the therapy for the screen a try and let me know if the laptop screen is healing. For the moment if you have one i recommend you hook up a VGA Monitor, old school stuff if you can and give the LCD a rest. I will post as a solution but comment back and i will keep helping you as much as you need it.
Dec 21, 2008 | Computers & Internet
RIM BlackBerry? Curve 8330 Cellular Phone Logo
155 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
