Question about Samsung HC-R5245W 52" HDTV
Lyp synching My Samsung rear projection has a problem with lip synching. The sound is delayed by a second so the "lip synching" is off. How can this be corrected?
  • Samsung Master
  • 8,617 Answers
There is a samsung TSS log for that problem. Heres what samsung says about it.
Tech must replace the following parts. This is a firmware software, and hardware fix. At the time of this writing the fix consists of replacing the digital, and light engine. It is Best to check their web site for the current part number because this is an evolving fix. Be sure you have the exact model number. Example HLN437WX/XX. This will insure that you will receive the right part number replacement.
Posted on Jun 15, 2008
Lip Sink issue, when playing a DVD Lips move & seconds later sound comes out.
Hello your center voice delay is set too high..Go into the audio menu(viewable on the tv) and reset the delay to 0 milliseconds.
Feb 21, 2011 | LG LHT854 Theater System
How are you? Good I hope. I recently purchased a Panasonic TH-P50U20A plasma and got a Soniq T500-AU HD Personal Video recorder for Christmas. I already had a Panasonic SC-PT470 DVD Home Theatre Sound...
I'm experiencing this lip synch problem with the T500 too. Not only that, but the soniq firmware upgrade (from their site) doesn't work either. And not only that, but the unit won't record from the EPG, and timer record looks like it is unreliable as well. The frimware file was on their site a few days ago, now I can't find it. They're promising a new website (URL?) soon. I'm none too impressed. Anyone got any ideas? Thanks.
Jan 03, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
My samsung DLP tv makes a humming sound when I turn it on, and it doesn't stop. What to do? Thanks!
You have to replace Color Wheel in Optical Block ASAP! Particles of shattered class have to be removed before installation of new part. Index delay have to be adjusted in service menu.
Mar 09, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Want to clean inside of tv want o hook up cieling speakers
Distance of where the ceiling speakers are mounted and where the TV is a factor. Sounds takes time to travel through the air. What you are hearing is a time delay most likely. Hope this helps.
Apr 12, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung 6768W DLP 2 yrs old Replaced lamp and now color is off Faces look like paint by number
possible solution:
  1. You may need to adjust the index delay after the replacement. You will be able to tell because you may see strange color banding in any scenes that have colors close, but not quite the same, in tone. This is usually most obvious in face skin tones (i.e. “clay faces”). If you need to adjust index delay, turn off the set, wait for the lamp to cool down, then hit mute-1-8-2-power in succession. The set should turn on with the service menu popping up eventually on the left. I don’t remember which submenu “index delay” is under, but find it and usually it will need to be lowered. I believe mine started out in the mid-50’s and had to be lowered to 47. These numbers are different for each Samsung model, so just adjust until the picture is pleasing to your eye. By the way, the supposed “correct” way to do this is to make the reddish part of the test color bar appear the “most saturated”, if you have a color calibration device.
Oct 15, 2008 | Samsung HLR6768W 67" Rear Projection HDTV
This can be from the source equipment, the program provider, or the way your audio system works.
The way to test this can be involved. It would mean using the process of elimination to determine where the delay is.
Jerry G.
Jul 15, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
Audio Out from Samsung LE40F86BD
check your samsung owners manual for audio settings to see if this model has a audio time delay setting .
Feb 26, 2008 | Hitachi 51F510 51" Rear Projection...
Sound/Video delay
Lip-sync error is a widespread problem caused when video is delayed and audio arrives too soon. Widespread enough that three different manufacturers make dedicated products to address it, in fact (see review link below for those three). It is present to some extent in essentially all broadcasts and DVD?s. If you have a recently acquired DLP, LCD or plasma display it may have added enough additional video delay to make it noticeable but lip-sync error comes from MANY sources starting at image capture and continuing through post production and broadcast or DVD encoding and it is cumulative. There is usually enough lip-sync error in broadcasts and DVD's to cause a negative impact on viewer perception (Research done at Stanford showed this.) Many people don't consciously notice it until it gets very large because it's such an unnatural phenomenon ( audio can't come before the action causing the sound in the real world) we apparently subconsciously avoid looking at the faces and seeing the lips move "after" the sound from them is heard. A study at Stanford proved this causes negative viewer perception even for those who don't notice it so this is something we all need to notice as you already have. For those reading this who haven't noticed it, take a close look at the LIPS - force yourself to overcome your natural avoidance mechanism that keeps you from looking at the lips - and you will see lip-sync error you never noticed before. I think you will be amazed that you could possibly not have noticed it before. You will be seeing what JC is seeing. I even see it now on CRT TV's and am amazed I never noticed it so it's very obvious some avoidance mechanism is at work. And back to JC?s solution: I'd recommend one of these digital audio delay units. That way you can correct for ALL cumulative lip-sync error no matter what its source might be. Any one of these units reviewed will correct it ALL. With any one of these units you can adjust for perfect lip-sync at the start of each DVD or broadcast and not disturb the image you are watching during that fine adjustment. I have had a Felston DD340 since 2004 (three generations earlier than the DD740 covered in the review) but it still has the most important feature of all these units from these three different manufacturers which is their "plus and minus" buttons on their remotes that allow you to tweak the delay while watching your material without upsetting the video your are watching. My av receiver has a built in delay of 80 ms which isn't even enough audio delay to offset the video delay my plasma display adds but even if it were it isn't practical to adjust it for the changes in lip-sync error from program to program and DVD to DVD since it overlays the screen with menus when making the delay adjustment. With my DD340 (and any of the units reviewed) all you have to do is press the plus or minus button until you get perfect sync. Here is the review I mentioned: [URL=""]
Aug 30, 2007 | Audio Players & Recorders
Open Questions:
See all Samsung HC-R5245W 52" HDTV Questions
Samsung HC-R5245W 52" HDTV Logo
71 people viewed this question
Jerry Greenberg
Jerry Greenberg
