Question about LG WM-2277HW Front Load Washer
LG WM-2277HW Error "te" THERMISISTER OR ELEMENT FAULT - How do I fix it
Washed a bulky load of horse saddle pads and this error came up - is it possibly a loose wire or connection? If so - where do I take apart the machine to check and what do I need to look for? You helped me once before with this machine's lint trap (BTW - the itty ***** rubber drain hose there for the trap is plugged with sediment - any way to clear that or change that? )
Thanks in advance with the price of fuel we just can't afford to call in a tech.
SPFhorsesthanx
  • 1 more comment
  • SPFhorses Jun 23, 2008
    Thanks! Stupid wire was broken off on thermisister.
  • Anonymous Feb 08, 2009
    te code thrown in first 5 minutes
  • carrie4rn Feb 21, 2009
    have thermisister but need to take front of washer apart, how do you take the front off
  • 487 Answers
I can give you THIS maybe that will help you . Service manual for your machine
Posted on Jun 19, 2008
  • eric bosman
    eric bosman Jun 23, 2008
    glad you were able to fix it. Please rate the solution thanks
TE error code problem How to fix the thermistor
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | LG WM-2277HW Front Load Washer
Te error pops up washer stops clothes still in it already drained filter not that bad
the thermistor is busted te means thermistor error need service technician tough job
Jan 05, 2011 | LG WM-2277HW Front Load Washer
Model wm2688hwm stop working screen show TE
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 12, 2010 | LG WM-2277HW Front Load Washer
Receiving a TE error code which leaves the washer unable to operate
TE is a thermister error. (temperture sensor) Located at the water heater element.
Supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing.
thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center.It easily pops back into place.
Apr 07, 2010 | LG WM-2277HW Front Load Washer
Error code tE, customer service recommended replacing thermoster, replaced but still getting error code. Can it be something else or does something have to be rest?
Ive looked through a service manual for your washing machine and that give the exact same fault and solution you mentioned (tE = Heater Error - The THERMISTOR is out of order)
Here is the service manual for you to look at:
WM-2277HW Service manunal
I had to scroll down to the troubleshooting section though but it has everything you would need to know in it.
I hope it helps
Regards
Mike
Mar 24, 2010 | LG WM-2277HW Front Load Washer
What doea the tE error message mean?
In the manual it does not have a cause... just shut off the power and call for service...
Feb 12, 2010 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Upside down F and E error message any ideas?
would that look like a tE or dE? TE is Thermistor error. Replace thermistor and check wiring back to control board. thermistor is accessible from bottom of unit reaching up to bottom front of tub. in middle of heater element it just pulls out of rubber seal.
DE would be a door error. is door open or did it lock when cycle started. door lock asm should fix this.
Jul 05, 2009 | LG WM-2277HW Front Load Washer
Lg rom reads error code te
Jun 21, 2009 | LG WM-2277HW Front Load Washer
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
LG WM-2277HW Front Load Washer Logo
1,495 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
