Question about Spc Personal Pitcher Pro Mini Polyball Pitching Machine
The 8 second feeder option wont work but the 5 second feeder option works 100% fine
Ya212 snap on wire feed low speed wont work
Open the cover and see if the feeder wheels are turning. They should, and likely are. if you increase the feeder wheel tension, this should alleviate some of that.
If it the feeder wheel is just not turning at the lower speeds but works fine and adjusts speed above the midpoint of the control, replace the potentiometer used for speed control as it may be defective- open on the carbon track.
Jan 15, 2012 | Welding Tools
My trackball will scroll down and across but it wont scroll up
Hi, Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100. I Hope it helped you.
Nov 26, 2009 | RIM BlackBerry 8800
My pearl on my balckberry wont scroll down
Nov 25, 2009 | RIM BlackBerry Pearl 8100
My track ball wont scroll up, what can I do?
Nov 22, 2009 | RIM BlackBerry Curve 8310 Smartphone
8220 , trackball wont go down
1. Select menu.
2. Select option.
Oct 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
AL-1531 blank copies at 100%
I believe the document feeder is just hesitating some, try pushing the original as soon as it starts trying to feed. It won't fix it, but you'll know where your trouble is.
good luck
Bob
Apr 22, 2009 | Sharp AL 1631 Copier
My toshiba a65 s126 laptop wont boot up
this is a windows baise problem re-install windows oprating system and after working fine
second think is your hit fan is not working proparly then temrachar is incrise and reboot your laptop.............ok 100% solve
Apr 01, 2009 | Toshiba Satellite A65-S126 Notebook
PAPERS WONT FEED THRU TOP FEEDER
im having the same problem was working fine then quit feeding
Mar 31, 2009 | Minolta EP4000/5000 CS/PRO Copier
Problems with paper feeder-wont feed through-chews up paper
I HAD THE SAME PROBLEM A MONTH AGO. I LOOKED WHERE THE PAPER LOADS AND THERE WAS A PAPER CLIP JAMMED IN THERE. I HAD A HECK OF A TIME GETTING TO IT, BUT I DID. AND IT WORKS FINE. MAYBE SOMETHING IS THERE.
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Spc Personal Pitcher Pro Mini Polyball Pitching Machine Logo
75 people viewed this question
Top Spc Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Spc Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
