Question about ASUS Computers & Internet
My asus K601 just shut down and i have been trying to reboot it or format it and it gives me an error saying cant find hard drive
  • 1,606 Answers
When you see this you either have a bad hard drive, or if you are real lucky its loose, or the drive controller on the main board is gone (not at a all lucky).
The first thing to check is to listen for the drive spinning up. You need to put your ear on the bottom of the case over the drive and then power it up. What you are listening for is the sound of just the drive. It should sould like a turbo spooling up. If there are any clunks or bearing noises then your drive needs to be replaced. Figure on $80-$100 for a new drive. Go as big as you can afford as its worth it. Replacement takes longer to explain than to do. You take the cover off then one or two hold down screws. Then the drive in its carrier comes out. Take the drive out of the carrier, put the new one in and put it back together.You will have to format and partition but that is all it takes.
It is very uncommon for the drive connector get loose enough to cause problems. Basically you take the drive out and put it back in and that is all it takes to fix it.
If the hard drive is actually good then the only thing left is the drive controller. To fix that means replacing the main board which can be up to a few hundred dollars. And the laptop needs to come right apart so there is a bit of labour involved. The total can be more than a new replacement laptop. This is rather uncommon but it happens.
The hard drive is the usual suspect. It spins up and down and is subject to damage if the laptop gets bumped or dropped. I'd start there
Posted on Nov 07, 2010
Blue screen on Asus k601 screen says
It has a virus. The whole system will need to be rebooted. You need to have someone back up your files and do it for you if you're not familiar with it. If you don't care about losing everything you have, then you can do a factory reboot yourself
Aug 23, 2014 | Computers & Internet
CANT FORMAT THE FLASH
I'm guessing that you got an error saying that something else is using this device, therefore you cannot format it?
If that's the case, you could do a lot of stuff to find the process that's using it and shut it down, but what's a lot easier is to just reboot into safe mode and try it again.
If you have windows 7, type "msconfig" into the search bar when you click your start orb. Hit enter once it finds the program. Click on the "boot" tab, then check the "safe boot" check box. Click apply then ok and let it reboot. Now you're in safe mode and nothing should be in your way of formatting your flash stick. :)
To get out of safe mode, follow the above directions again and just uncheck "safe boot."
If the stick isn't being recognized by windows at all, like you can't even see it in explorer, then chances are it's not initialized. Let me know and I'll walk you through that process next if none of the above helped and this is the new problem.
Mar 07, 2014 | Kingston DT100G2/16GBZ 16GB DataTraveler...
My operating system was accidentally deleted from my Asus netbook. I want to reboot it with a bootable pendrive but it doesnt work. It gives the message, NTLDR is missing,press ctrl+alt+del
Below is Microsofts solution to your error. Reload the OS with a Microsoft CD format it completely not the fast format option reload from sctratch. If you have no CDrom use an external.
Systems hard disk drive has FAT32 file system. Computer hard disk drive has INT-13 extensions with a system-ID type of 0C in the partition table The heads value in the FAT32 BIOS Pattern Block (BPB) is inaccurate.
To resolve the error message "NTLDR is Missing" follow the below steps: Boot the computer with a Windows 95 or Windows 98 Startup diskette or another bootable diskette with sys.com on it.
At the A:\> prompt type: sys c: <press enter> After pressing enter you should receive the prompt "System Transferred". Once the file system has been transferred reboot the computer without the diskette and attempt to reproduce the error.
Aug 23, 2011 | ASUS Eee Pc 1000Ha 160G Netbook
My netbook boots only to the word window
Sounds like the HDD is corrupted what you need to do is goto the drives manufactures website and download their hard drives utilities software,
follow the instructions on how to make a bootable disk then shut down the computer reboot and run the utilities software, if you have nothing you need to save off the drive, Then do a low level format this can take upto an hour or more depending on how big the drive is
once you have done the low level format (this wipes everything off the drive) then reboot the system and format the drive in windows this will rewrite the master boot record in windows format
some manufactures don't have a format utility because there are so many differentsystem file formats.
Feb 28, 2011 | ASUS Eee PC 1000HE Netbook
My asus K501J was suddenly working then i turned it off and went back on a couple of hours later and every time i turn it on now it goes to the asus menu thing and then it goes black. What should i do?
When you go to turn it off do you use the power button, or do you go to start and shut down? If you shut it off by the button this is not good, you can corrupt your files by doing this because it doesnt give Windows the chance to close its needed files first. Excessively using this will definitely cause damage to your computer. If you are able to get to the ASUS logo at startup, try to the following.. reboot and when you see the logo hit f8, you will then be taken to a black screen that gives you a few options. Arrow down to the option that says Safe mode with command prompt and hit enter. You will then be redirected to another black screen with a command prompt that looks like this.. C:\***** . At the C: type the following, chkdsk /f this will test your hard disk for errors and should repair them as well. Once this is done type exit and reboot, you should be able to boot into windows successfully now. Let me know if you have further issues as we will go to step 2. Hope that helps and gets you goin!
if you found this helpful, please leave feedback, thanks
Lori
Oct 17, 2010 | ASUS (90N804SH021) Hard Drive
How do i fix error 8002f1f9
1. reset ps3 to defaults using recovery menu. 2. begin installation using the same fw version. (hard disk must be formatted externally if u get error 8001002b)
3. when it hangs @ 73% or whatever. Shut down and remove the drive
4. begin the installation of the system inserting the drive into another ps3
5. after it reboots, press (PS), at the disclaimer shut down, remove the drive and put into the broken ps3
6. boot normally...it ask to format the drive...
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Network adpter malfunction
try this
Uninstall any drivers for card shut down remove card restart then shut down reinsert card reboot on reboot it should come up with message new ??? found and go into finding drivers follow instructions to install them from where the driver folder is
when installed reboot normally this will fix problem
Jul 27, 2008 | ASUS Computers & Internet
Gforce 6100sm mv 1.0 loading xp64
i think trojan horse is attacked to ur hard drive instal some good antivirus and give for search ..
if problem persists then give full format dnt give quick format ...
if there are many partitions then the only way to get rid of the problem is to delete all partitions & by repartitioning your problem will be solved.....
Nov 14, 2007 | Intel Motherboard
Computers & Internet Logo
256 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
