Question about Amana Heating & Cooling
I have an Amana RHE30A2B heat pump. I installed a new thermostat, Honeywell, last night and now the coils are not cooling & the unit is blowing hot air. I have double checked all the wiring & everything seems to work as it should. Is there a breaker or fuse on the outside unit that I am not aware of before I call a service man out. We also had an electrical storm last night. It could be a freak thing, but I am still concentrating on the thermostat.
  • 1 more comment
  • crashea Jun 15, 2008
    One of my kids ran into it going down the hall and broke it. The fan on the outside unit kicks on, but the compressor is not kicking in.
  • crashea Jun 16, 2008
    I found a breaker on the outside unit and reset it. The compressor is kicking on now, but it is blowing hot air. The pipe is almost too hot to touch. The thermostat is doing what it is supposed to do and the compressor seems to be the problem, unless it is just out of freon. I don't think there is much more I can do with it unless you can think of something. I will call a tech in the morning. Thanks
    The service tech was just here. The problem was the thermostat wiring. On the old stat, White-Rogers, there was a wire running to "L". On the new stat, Honeywell, it had to run to "O". Everything else checked out fine. The tech said that, depending on the brand of stat, there is about a 50/50 chance on the way it should be wired. It seems like it would be a fairly common problem, but I did not find anything on White-rogers, Honeywell, or Amana that even gave a clue. Maybe this will help someone else in the future. (Symptom: After installing new thermostat, everything works correctly except compressor is blowing hot air.) Thanks for your help.
    Guru:
  • 859 Answers
If you can hear a click or see a light when you turn your thermostat from up to down you do have power there. Or, you can put a meter on your thermostat and see if there is any voltage or not. If not in either case, you can try this if you feel qualified around live power.
Turn off the circuit breaker to your heat pump at your master circuit breaker on the home. Tape that circuit breaker open with red duct tape or regular duct tape and don't let anyone near it while you do the remaining.
Remove the electrical service panel at your heat pump.
Look for a service panel breaker, reset or inline fuse.
Replace or reset if able and see if your heat pump comes back on when you turn your circuit breaker back on and your thermostat is down to 60.
Since you say you had an electrical storm when this occurred I would be surprised that your master electrical panel didn't pop your circuit breaker out to your heat pump. Failing that the service panel on your heat pump should have popped a fuse, reset switch or breaker. Failing all of those, you will need service from your a qualified service tech for your model maker. Your home owner's policy may cover expenses above your deductible. It would be worth a call to your Insurance company should the voltage rectifier circuit on your heat pump have been destroyed by the electrical storm.
Posted on Jun 15, 2008
  • Glenn Rogers
    Glenn Rogers Jun 15, 2008
    I agree with Master Tech on this. Are you qualified to run this down with a meter and replace a cap?
  • Glenn Rogers
    Glenn Rogers Jun 16, 2008
    The fact that your compressor is not putting out cold air does concern me and it is probably not out of freon. That just wouldn't happen from your breaker popping on the service panel. Your compressor may have indeed popped a sacrifical cap or diode to save itself due to the surge.
    One thing you can do for your home, by a licensed electrical contractor is put in a whole house surge protector that mounts at your master circuit panel breaker box.The unit itself sells for around 200 dollars and the electrician can have it installed in an hour. This way it will protect all your electrical units in your home whatever they may be from power surges from electrical storms.
    Regards and good day,
    Worldvet
  • 770 Answers
What casused you to think the thermostat was bad?? Check for power at the compresser and or see if the compresser is running first........If so then feel the freon lines at the rear (outside) ones getting hot if not and the ecompresser is running you have a leak in the system and it is low on freon.
  • Gary Davd
    Gary Davd Jun 15, 2008
    You will need to check for power there is a Capacitor also that is tyed into the Compresser check to see if that is ok you need to find out where the power is missing/ Also note since the fans runs you need to see the wiring feeding the compreeser from the control panel
  • Gary Davd
    Gary Davd Jun 16, 2008
    there are two lines the one (small line) should be hot the larger line should be cool almost to the temp of a can a coke you took out of the refrig this line usally has insulation around it. If the they are not and the compresser is running then it is a freon issue I would shut it down unit a tech can check the pressures
    Guru:
  • 1,894 Answers
It may be the fuse that has blown out.
but not sure.
if fuse is out the whole unit wont start i think
  • dewan nafees ahmed Jun 15, 2008
    there is a fuse in all kinds of unit.
    and there is a protection circuit for every unit which can prevent the unit from any damage.
    so please make a double check of the fuses.
3 amp fuse keeps blowing when heat is on. Took advice of repair person and purchased and installed a Honeywell 5000 Still blowing fuses. Super frustrating We have 4 year old Goodman heatpump a unit Any...
the reversing valve has an electric solenoid, if it is energyzed for heat mode, then try replacing or testing the solenoid coil. the coil may be going out drawing more amps than it should.
Dec 24, 2017 | Honeywell Heating & Cooling
Dear Sir,I have an Amana Distinction 2.0 Ton heat pump, SEER 14 installed in my department about 4 months ago. I've noticed that the AC has a regular pattern running in the on/off cycle and that i
You need a tech. All 14 seer units have an X13 motor which speeds up and down on start up. A tech will adjust your tstat programing. Fan stays on after unit is done cooling to help drain water in cooling and cool off heat strips in heating,
Jun 15, 2013 | Heating & Cooling
My Honeywell PRO 4000 Programmable Thermostat is set to 62 but last night went to 74 & then to 78 & heat would not go off. We have a Trane XB furnace - Both 5 years old. Took face plate off...
You probably have it running a program. Try using it simply on heat mode. Then set temperature and press hold on thermostat. The word hold should show up on the screen.
Feb 02, 2018 | Honeywell Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
I install new RTH7500D thermostat Honeywell, when I set for Cool it blowes heat when I set for a Heat nothing works I wire per instruction have two stage system
It sounds like the t-stat is programmed for a heat pump or you have a heat pump and the t-stat is programmed for a regular furnace....
Check out the manuals in the tip and go into the installer setup to change the t-stat to the proper programming for your system..
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
heatman101
Apr 24, 2010 | Honeywell Programmable Thermostat Heater
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
After RTH6400 installation heat strip is no longer actuated
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Do-It-Yourself/Programmable/5-1-1/Default.htm look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
Not heating
Yes, the reversing valve has a separate coil. some energize on cool mode, some on heat mode. Has the thermostat been replaced? I find this a common mistake.
Nov 03, 2007 | Amana Comfort Zone 18M33PCEH Air...
Heating & Cooling Logo
207 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
