Question about Maytag MMV5165 Microwave Oven
Oven overheated power died how to reset - Maytag MMV5165 Microwave Oven
  • 320 Answers
A thermal fuse might be busted. Have it replacedby a qualified technician.
Posted on Nov 07, 2010
Maytag umc5200 microwave dies when oven runs too long
Sounds like it is overheating. Make sure you hear the blower fan running and If it is, you have another connection overheating inside the unit. Maybe at fuse or fuse holder??!!
Oct 23, 2017 | Microwave Ovens
Had a power outage and microwave died. is there a fuse or reset button somewhere?
there is usully a fuse inside all microwaves. they are avalible at most hardware stores and home centers
Sep 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My H5640 microwave has stopped heating food and cuts out after 40 secs - is there a reset button or is it a "bin and buy another one" job
Sounds like it's time for a new oven. The magnetron tube that makes the microwaves is overheating and causing the safety thermostat to cut off power. Normally, with the cost of the replacement tube and repair labor, it's more economical to buy a new oven.
Jun 13, 2010 | Neff H5430 Convection Microwave Oven
No power everything was fine then nothing when i got home is there any fuses to check in the microwave
There is a fuse under the cover, as well as a couple of safety thermostats that can cause a dead oven. It may also be that the power transformer for the control circuit board has failed. I've seen several Sharp ovens where the transformer died because of power surges. This would cause no display and no functions even though the oven has power. Also, did you make sure the outlet your oven is plugged into has power? If it's a GFI outlet it may need to be reset, or a circuit breaker in your electric service panel may have tripped.
Hope this helps, and thanks for using Fixya!
Feb 28, 2010 | Sharp R-1850A Convection/Microwave Oven
Sometimes while using the oven it appears that after a while the heating stops ( due to overheating )and all functions switches die. After some time (cooling down) the oven can be used again. Could it be...
It's far more likely that one of more cooling vents has insufficient space around it; the instruction book will tell you what the clearances should be.
If none of the vents are obstructed then it's likely that one of the oven cooling fans has failed.
The last item to suspect after eliminating other causes is the overheat protection device.
Oct 28, 2009 | Daewoo Microwave Ovens
Microwave power seems to have died
My advantium 120 died and it has power to the oven but it does not work! does the oven have a fuse that i can change?
Sep 29, 2009 | GE Advantium 120 Convection/Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag microwave overheated.
There is a fuse that should be easy to get to behind the control panel.  Will need to take the grill off first to get control panel off.  Make sure unit is unplugged first.  There are high voltage parts in a microwave so you should have a professional do the work if you are not comfortable with it.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Maytag MMV4205 Microwave Oven
Maytag MMV5165 Microwave Oven Logo
113 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
