Question about Sony Playstation 3 (PS3) Console
Systems tries to update and freeze at 99% and want go any futher
  • swidmans Nov 07, 2010
    when system comes on it automatic goes to system update and began to install the only way to stoop it is turn off system when i turn it back on it starts updating again
    I tried to do that several times and each time when i let go after the 2 beeps a system update pop up and starts to install the only way i can stop it is turn off the systems
    President:
  • 1,139 Answers
Can I suggest you download the update to a memory stick with at least 256Mb free space on it. Create a directory on the memory stick called PS3, then inside that directory create a new folder called UPDATE. Put the update file into the UPDATE folder. Now back to your PS3
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and turn back off into standby. Release the power button.
Press and hold the power button again. It will beep when you first press it, then 5 seconds later it will beep again, then there will be 2 quick beeps together. Let go of the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect a controller via USB and then press the PS button. Do then and then continue.
The PS3 will now load a menu. Make sure your memory stick is plugged into one of the USB ports of the PS3. Choose option 6 on the menu, "System Update". Follow the on screen instructions to install an update from an external device. Hopefully this should sort your problem for you.
Posted on Nov 07, 2010
  • Kevin Penn Nov 07, 2010
    If you follow my instructions to go to the system restore menu it wont actually turn on fully if you get what I mean, the recovery menu kicks in before the PS3 loads up properly. This menu was designed for problems just like this, Give it a go and see how you get on
    Ok, if it is not letting you access even the recovery menu then I am afraid you have severely corrupted firmware that only a replacement from Sony is going to fix. Give them a call and see if they will replace the system for you, explain that it went wrong after trying an update. They will probably tell you to do the holding the power button sequence but if this definitely does not work then it needs to be sent away.
    Sorry I cant be of more help
Downloaded 4.3 update and it freezes at 99% during installation
its most likely a connection problem if not unplug Xbox, wait 10 minutes and try again, if all fails call Xbox live!
Feb 19, 2013 | Sony Playstation 3 (PS3) Console
Ps3 froze installing system update
Cut it off. This should not mess up your HDD. Then i would just try again.
Dec 01, 2011 | Sony Playstation 3 (PS3) Console
I was doing a system update and it stops at 99% I called sony we tried to get it in safe mode but when it starts back up it starts downloading update again and it freezes at 99
you called sony and they let you off the phone with no solution, I would try it on another network somewhere to see if the problem re-occured. If it did I would not let them off the phone until we reached some form of resolution.
Rylan
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
Samsun SH-s202N & Nec Rewriters will not burn DVDs over past fews
Yes, SP3 has known to cause this issue. Let me check further for you..
Jun 01, 2008 | Samsung TS-H552U DVD±RW Dual Layer...
Magellan RoadMate700
I think Magellan makes it so if you don't update your map every year it will freeze up. Mine does the same thing and they told me to buy an update for $99 last year so I did and it worked and then after it started telling me my map was over a year old this year it started freezing up again. I don't want to pay $99 every year to keep this thing working. I wonder if Garman or Tomtom does the same thing.
May 31, 2008 | Magellan RoadMate 700 GPS Receiver
My 700 gets stuck with the last map
Same problems, you have to update as far as I know and you have to update every year otherwise it will start to freeze up. It's a rip off because it's $99 a year. Does anyone know if the other GPS companies do this?
May 14, 2008 | Magellan RoadMate 700 GPS Receiver
Download freeze
Is this when you try a second and third time to download the same movie? Try a different one. Update to version 2.2 (came out last night). It has upgraded reliability for the internet. Hopefully that helps. Good luck!!
Mar 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
53 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
