Question about GE Washing Machines
GE model #WJRE5500GWW is not turning on when i push the rubber button in the right side of the machine. What other way can I do to turning on?
  • 8,197 Answers
Sounds like you need to replace the swith to make the machine to work. good luck
Posted on Nov 29, 2010
Have a, GE refrigerator side by side model PSS26SGRBSS not cooling right when push the tubo cool button show a, code E2 plus the fan in freezer side not working at all
Most likely the=> WR60X10099 Fan is defective. If after replacing the fan it still does not work you will need to replace the=> WR55X10942 Control Board as both will need to be replaced if fan was damaged by the control board.
APPLIANCE 911
Aug 07, 2016 | GE Refrigerators
Why won't my washer start when I push the start button
My washer use to not work and I took off the rubber cover that covered the button and was then able to just push the stem inside to start the machine. It worked fine afterwards.
Feb 19, 2015 | GE GLWN2800DWS 638 3.9 DOE cuft capacity...
GE Hydrotemp Front Load washer shutting off every 10 minutes
when the machine shuts off can you open the door ? /will your machine restart straight away when you push the start button ? / does this happen on all programes ? let me know as this will help me to solve
Jan 04, 2012 | General Electric WHDVH660H Front Load...
My dryer doesn't turn on. There is power but the start button isn't working
it may be the the door switch or you can try resetting the motor:
1) unplug dryer
2) put dryer on its front side
3) lift up the bottom of the dryer(so that you can see into it) you should see on the right side small red reset button.
4) push the reset button in.
5) put machine upright and plug in
If that does not work then you will have to short/jump out the door switch. Hope this helps Tim
Oct 02, 2010 | GE DBXR463EDWW Electric Dryer
I have a GE washer WJRE5500GWW. It makes a loud grinding sound during agitation and spin cycle.the spin seem a bit slow but it pumps out the water just fine.
its your drum bearings going there just about worn out,,not a cheep job to fix sorry,,,soon it will start leaking water from the drum drive shaft!!!
Jul 15, 2010 | Washing Machines
GE Washer WJRE5500GWW drum spins back and forth on agitation. Had the Shaft tube assembly replaced 10 months ago. Did it blow again?
Nah, your drum brake/clutch just started slipping. Just replace that and you'll be back to good.
Mar 24, 2010 | GE 3.2 cu. ft. Washer
Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
May 07, 2009 | General Electric DCVH640GJ Gas Dryer
How to turn on the alarm and turn it off
To enable the alarm, push and hold either alarm 1 or alarm 2 button on left side of face... eventually it will switch the display and say alarm enabled and you can then push the alarm button to switch between buzzer / radio / off.
Nov 18, 2008 | GE 2.4GHz Cordless Bedroom Phone
Problem with my GE dryer
  • turn your circuit breaker off then back on. sometimes the only one side of the dual 220v breaker will trip leaving you with a non functioning machine thats seems to have electricity going to it.
  • another thing to check is the door switch.
Jul 06, 2008 | GE DCSR483EA Electric Dryer
NEW WASHER WILL NOT SPIN OUT ALL WATER. DRAIN IS NOT KINKED AND IS AT 48 INCHES OFF FLOOR. MODEL IS WJRE5550H1WW WE HAVE IT ON EXTRA SPIN AND WE MATCH LOAD; MED SIZE LOAD / MED ON COTTON SETTING
I have the same problem, I called GE and they said there is definitely something wrong with the machine if I can just wring a bunch of water from the clothes and suggested to put a service call, seeing as I bought it last week I am going to see if I can get lowes to replace it with a WJRE5500GWW instead.
Jun 02, 2008 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
