Question about Sub-Zero 632 / S
Took my sub-zero 632 ice drawer out to empty it, and i can't put the drawer back in. the tracks don't seem to be broken. how do i put it back in? thanks in advance, bill whittier
    President:
  • 2,777 Answers
I have worked with this fridge numerous times and the ice drawer should just line up with those tracks, and push in until it locks into place.
I am looking at the documentation and it confirms that there is no real trick to getting it back in there, it should just line up and push in.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 07, 2010
I cannot figure out how to install the left had rail for the Ice drawer on my Sub zero #632 refrigerator
you have to remove both screws in both rails, and pull the whole carriage and rail out as an assembly. then replace the rail, put the whole assembly back in, making sure to line up the hooks on the back of the rail with the screws way back in the back that aren't removed. then slide the ice bucket carriage back all the way in and put back in the 2 screws in each rail. good luck!
Dec 10, 2013 | Sub-Zero Refrigerators
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Ice drawer
Call the factory at 800-222-7820 they will walk you through it and send you a manual.
Oct 23, 2008 | Sub-Zero 632 / S
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Sep 30, 2008 | Sub-Zero 632 / S
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Sub-zero 632 error code 24
clean out auger bucket ec-24 is defrost underheat,to clear press and hold bell on/off key for 15 seconds.
ALL APPLIANCE REPAIR L.L.C
HOT SPRINGS
Feb 28, 2008 | Sub-Zero 632 / S
Sub Zero Frezzer drawer
I had the same problem. I found the piece of plastic in the ice tray and couldn't figure how to put it back. I ordered a new ice flapper from the parts place on the internet and installed it. The ice maker now shuts off. Good Luck.
Rick S.
Oct 26, 2007 | Sub-Zero 650 / O Bottom Freezer...
Ice maker drawer for sub-zero 632
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Aug 02, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
184 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
