Question about Sub-Zero 695/O Side by Side Refrigerator
MODEL 695 ICE&WATER DISPENSER. Intermittent operation opening /closing ice dispenser cylindrical gate door. Sounds like sticking relay or cylinder sticking. Can I repair or can I buy this assembly and replace it myself? Or should I get a Subzero repairman because of the complexity? Thank you
  • pjf99 Nov 07, 2010
    I think you are right. Any additional thoughts about a chance of a possible quick fix? oil a bearing, hit the fridge in the right place?
  • 6,993 Answers
repairing this yourself depends on your technical ability.
I would suggest you get a repairman so that you won't damage anything further. Usually, this requires a profession touch.
Good luck.
Posted on Nov 07, 2010
Water dispenser not working
Should have posted the model number, based on your issue, it sounds like a intermittent water valve, should be replaced,a bad dispenser switch, or a faulty relay on the main board.
Apr 28, 2014 | GE Refrigerators
Ice and water dispensing intermittently on my Maytag model MF2568AES12 refrigerator. I replaced the light switch in the freezer, which didn't help. What should I do next?
On top of the fridge underneath the plastic cover for the door hinge probably on the door with the water/ice dispenser should be a wiring harness. This runs the ice dispenser and water. There should be a wiring harness plug there. Try unplugging it and reconnecting. This may be the cause since you said it's intermittent and with opening and closing the door it may be causing the plug to ever so slightly move around and loose electrical connection.
Oct 18, 2013 | Maytag Refrigerators
Subzero 695 Ice/Water dispenser problem.
maybe ice formed around chute from leaky air seal??? warm area with hair dryer blowing hot air up into chute for 10 minutes. check for water and wipe all off. unplug refg and plug in after 3 minutes to reset electronics
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Sub-Zero 695/O Side by Side Refrigerator
My ice and water dispenser sticks. I have to open
The door flap may not be opening and closing completely thereby trapping the ice. There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 13, 2010 | Jenn-Air JSD2789GES Side by Side...
ICEMAKER FROSTING UP
Try to take some ice from the dispenser. Remove the glass and open the freezer door to look down inside the dispenser chute and see if the trap door has re-closed. If it remains open warm, humid air will enter the ice bucket and gradually freeze the cubes together. Trap door remaining open is generally caused by a rusted electrical coil which pulls the door open electrically then sticks, unable to re-close. Coil is located behind the panel that operates the dispenser. Relatively easily accessible.
Jul 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door light, on/off switch, water and ice dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it.
if you are still having trouble please respond with a model number
Apr 15, 2009 | Refrigerators
Water/Ice Dispenser Does Not Consistently Work
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Sub-Zero 695/O Side by Side Refrigerator Logo
253 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
