Question about Welding Tools
My 211 Millermatic welder is experiencing burnback no matter how low I set the power. Why is it and what can I do to stop it?
  • eaishizuka Nov 08, 2010
    Check to make sure the wire is actually in the drive groove inside the machine. Also try running the wire to see if it is pausing and that is causing what may seem like burnback.
  • 407 Answers
Your problem rely on the initial settings, your voltage is too high or your wire feed speed it's too slow. Compensate both, or just decrease you voltage.
Posted on Jan 12, 2011
HOw do i fix a help 7 code on my millermatic 350p welder
If you have three phase or 110 v supply it will not work.
May 04, 2018 | Welding Tools
I have power to the gas solenoid on my millermatic 211. however no gas to the tip. tank 3/4 full. have gas to flare fitting that attaches to unit. do you think bad solenoid?
Guessing you measured the power at the solenoid and therefore you have a voltmeter.
Disconnected the solenoid wiring and measure the Ohms across the coil of the solenoid.
You should read some relatively low resistance 200, 500, 5000.
Not meg-ohms.
Feb 07, 2018 | Cars & Trucks
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
New welder, only fed wire a couple times now it wont work
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
May 05, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
Burning up tips fast with Miller S-22A
tooslow and probaly too close to work piece try turning heat down a little also make shure you have a good ground/ maybe angle your gun a little more
Dec 17, 2012 | Miller Welding Tools
Copper end of wand and parts inside of wand have melted. Is there a replacement?
Melt?? well looks like you had a burnback problem. There are contact tips, nozzles and gun liner available. Go to your nearest welding shop and ask for them. Around 35 bucks for all three (if you need the gas mixer known also as tip holder add 10 buck more).
To avoid burnbacks, reduce your voltage or increase your wire speed.
Jan 11, 2011 | Clarke Power Products Clarke 130EN Mig 110...
What mig welder would you I buy to restore a old car.
I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
Oct 28, 2010 | Clarke Power Products Clarke 130EN Mig 110...
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Welding Tools Logo
166 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
