Question about Sony Televison & Video
Flashing light - TV shuts down
We replaced the lamp about a week ago, everything was working fine. Now the television runs for maybe 1/2 hour 45 minutes and shut off. No timers are set, but the red light flashes on the front of the television 9 times in a row when the set shuts itself down. Do you have a solution for this?
  • Sony Master
  • 8,617 Answers
I will need the model number of your set in order to help you, but different models have different meanings for the error code. Your set is flashing an error code. Please respond to this and I will be able to help you with the problem.
Posted on Jun 15, 2008
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
HLR 5067W 6yrs old. I replaced the lamp and color wheel about 3 years ago. Last week the TV would not turn on. Fans run hard, no light from the lamp. Tries for 3 cycles, then shuts down and front...
Tv is on every day and watches 4 to 5 hours every day?Yes,3 years now the projection lamp require replacement again and the board that call the Ballast board might require replacement too,this Ballast board only job is it to ignite the projection lamp only..
Jun 04, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
Hello, I have a Samsung DLP HLR5667 and it blew a lamp 4 months ago, I replaced the lamp and it worked fine for about 2 months and started shutting off after only running for about 90 seconds. I reset the...
You need to replace your color wheel. This is a very sensitive part and you need to take care when replacing. If you feel comfortable I can walk you through it. If not, I would take it to a authorized service center.
Apr 18, 2011 | Samsung Televison & Video
Now the power shuts off consistently. Says on for a few seconds and the picture looks Ok but it powers down and powers up again on its own.
Tv "LAMP" LED light is flashing?Yes.Projection lamp might have to be replacing?LAMP been iside the tv like 1 1/2 or 2 years,tv used daily like 4 or 5 hours a day?Yes,replaced the projection lamp,will solved the problems.
Feb 14, 2011 | Samsung HL-T5676S Television
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
Just replaced the bulb. the tv works fine for 5
Ck Fan to Lamp it maybe Defective if fan stops running then lamp shuts off this is to protect Lamp from getting to hot Call Mats for Parts if it is the fan and Ballast Board is what turns Lamp on. 1-800-628-1118 they sell all supplys for TVs
Sep 26, 2009 | Sony KDS-R50XBR1 50" HDTV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Dec 23, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
