Question about Kohler Home
Kohler jacuzzi, whirlpool bathtub will not switch on. Checked power, looking for reset switch. cannot get jets to turn on.
  • 2,382 Answers
Hi, first check the air switch hose that connects to the "button"
Open the access for the pump there should be 1/4" poly tubing (probably clear) that connects to the pump motor. It just slides over a barbed nipple usually located somewhere on the back of the pump housing opposite the pipe connections. Make sure it is in place properly. If it is in place then look else where. The tubing also connects to the back of the air switch "button". This button connection rarely fails, especially if the tub was working and now does not. But if the tub is newly installed and may have disconnected during installation. this connection is probably going to be difficult if not impossible to verify since it is usually concealed after installation.
Some pump motors have resets some do not. If it does it probably is on the very back of pump oppositethe pipe connections.
Also check to make sure that any electrical outlets in the bathroom, or any where in a nearby radius of the tub, to see if they have "GFI" reset buttons and make sure that they havn't tripped by pushing in the button between the plug-ins named "reset". Usually the circuit for the pump will be tied into one of these switches to add ground fault protection to the circuit.
If your pump is not working after checking these things it may be dead. Does your pump "hum" after pushing the button? Do you smell any type oder around the pump that would suggest a "burnt motor"?
If the pump is dead you will have to replace it.
Posted on Nov 07, 2010
Will epsom salts harm whirlpool
DO NOT use products with glycerine or oil in any Jacuzzi or whirlpool bath. It will harm the jets. Label oil or glycerine-containing gifts, "Not for Jacuzzi or whirlpool!"
May 03, 2012 | Kohler K-1110-AH-0 Purist whirlpool with...
The light will not come on after starting jets and the reset button has been reset. The water is hot in the tub. brand new unit
i have the same problem, checked ohm's there good at 15, why won't the rapid heat light come on letting me know t's working?
Jan 16, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
My kholer jetted jacuzzi tub will not come on or do anything...just bought this home and to the best of my knowledge worked prior to.
make sure there is power to the pump. Some of their model require you to be in the tub full of water before the pump will turn on.
Dec 16, 2010 | Kohler Home
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My american standard jacuzzi tub is pluged in but jets won't turn on
check for power at plug in if power your vacume switch is probably out replace switch.
Apr 28, 2009 | American Standard 2771.002.021 Cadet 5' x...
Kohler Whirlpool tub motor wont turn on
Kohler Whirlpool tub turns on and shuts right off. Reset gfi and motor turns on and shuts right off. Help
Mar 15, 2009 | Kitchen Appliances - Others
Home Logo
1,520 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
