Question about Watches
I have a WALTHAM DOLPHIN CHIME ANNIVERSARY CLOCK PORCELAIN It uses 2 AA batteries and a red button to set the chime, but I have lost my instructions. Can you help?
  • Bobbie Strong Nov 10, 2010
    Yes I was satisfied with my answer. Thank You!
  • 1,606 Answers
The actual Waltham company went under in 1954 or 1955 I'm not sure who is actually making these. Good news is if you contact your local Sears store they do sell these exact model clocks. Usually someone in the department will just open a box and look at the manual for you. They may even have a spare one or be able to let you know how to get one.
Posted on Nov 08, 2010
How to turn-off chime of elgin Westminster chime wall clock with pendulum?
Are there two batteries. One for the time and one for the chime? Try taking the one for the chime out and it should stop chiming. mine worked that way but is a different make.
Feb 04, 2017 | Elgin Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    I have an Elgin anniversary clock that was made by Nisshan Clock Co in Japan. It has no back anymore, it has a red and black button and is powered by one D cell battery. The time is correct but the
    Sounds like the element is bad. It is replacable and available online at several places, I have one like yours and that is what I did, its easy to do and will get you ticking in no time
    Jan 10, 2015 | Elgin Watches
    Elgin Anniversary clock chimes early
    take the big hand off and move it back one square on the shaft
    Nov 11, 2012 | Watches
    I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
    I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
    Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
    I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
    Hope this helps!
    Feb 07, 2011 | Watches
    How do i synchronize my chimes on a westminster quartz abacus 401c wall clock
    If it is like mine you press the test button until you hear the chime. Wait for the hour chime to go and count it. If it chimes once for 1PM and you need it set to 6PM then you press the test button to reset the chime and repeat press the button 5 times. This will set the chime to 6 PM. If you get lost on the time press until it makes no noise. This means you are 11PM or later and continue to then press until it makes noise again. Count the hour chimes and you are at the count in the AM. Repeat the steps and keep pressing to get to the proper AM or PM hour count..
    Jan 16, 2011 | Watches
    We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
    Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
    Nov 19, 2010 | Watches
    Quartz president wall clock, I need to set the chime
    I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
    *Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
    *Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
    If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
    John
    Apr 21, 2010 | Watches
    Timex westminster anniversary chime clock doesn't chime correct number
    Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
    Oct 04, 2008 | Watches
    Watches Logo
    439 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
