Question about Baby Lock Ellure
I have a BabyLock ellegante. I am using a walking foot to quilt in the ditch. I am using Madeira invisible thread in needle and a Madeira bobbinfill in bobbin. The problem is that the machine keeps starting and stopping. As soon as it sews several stitches, it stops and does not respond to the foot pedal for several seconds. The constant starting and stopping has me crazy. What is wrong?
  • 106 Answers
SOURCE: babylock ellegante threading problems
It is something I cannot explain how to do on here, you need to be shown, would suggest you get in touch with a sewing machine tech.
Posted on Mar 28, 2008
  • 3 Answers
SOURCE: needle thread breaks while quilting on machine frame
I think you might have better luck if you use 40 or 50 weight thread.
Posted on Dec 20, 2008
SOURCE: thread gets caught on bobbin and jams
You may need a new bobbin case if your machine is an older model.. Over time the cases get nicks in them causing thread to catch on it. Have you lubricated the bobbin area? Needs one drop of oil for every ,I believe it is 25 hours of usage. That may take care of it. The oil goes under the bobbin right in the center of bobbin case. Remove your bobbin before applying the oil. i hope this helps you. Good Luck
Posted on Jan 08, 2009
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
  • 4 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Are you threading it correctly? I've had this problem twice, the first few times the thread was wrapped around different items (below the spool holder and then around the needle) the other times I threaded it wrong. Double check that the machine is threaded correctly with the manual. I've missed a step here or there and it does make a difference.
Posted on Jul 29, 2009
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
I am using my walking foot to stitch in the ditch my quilt. The foot is not pulling my fabric through consistently.
The quilted fabric may be too thick for the walking foot to move along smoothly. Try using a zipper foot which is much slimmer and can get close to the line of stitching.
Apr 18, 2015 | Brother CS6000i Computerized Sewing...
Which foot do I use for quilting
a quilting foot or buy one with a round hole in it great
Mar 09, 2015 | Sewing Machines
How do I stitch in the ditch for 103 a straight line of 103 inches without wavering.
I draw a line on the fabric with a sharpened bar of soap. then hold the fabric as far away from the needle as you can. It will help you stay straight.
Dec 17, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Brother cs6000i thread tension issue
Logically, the top thread should not be affected by a walking foot as the thread operates independently of the presser foot.
Suggest removing the top thread totally from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Check that your walking foot is installed correctly--the fork-shaped piece needs to encircle the needle clamp screw.
If you continue to experience problems with the walking foot but none of the other feet, recommend contacting a Brother technician.
How do attach the walking foot Brother
Jun 26, 2017 | Sewing Machines
How do you replace throat plate on Babylock Imagine Wave serger
I had to replace the Needle Plate on my Babylock Ellegante machine and when I turned on the machine it told me to Turn off power and replace the Needle Plate. which I had already done. How do I fix that so I can sew. thanks Jan billawp@tds.net
Jul 14, 2012 | Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches and noises
sounds like there might be some threads caught between the tension discs. Try using a small strip of fabric to 'floss' between them. You might also have some thread caught in the hook assembly.
Feb 25, 2008 | Bernina Artista 180
Sewing Machines Logo
43 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
