Question about Polaroid FLM-3732 Television
Turn on tv, when blue screen comes on I get a high pitched sound Can I get a copy of the schematics of this model to repair and replace parts as needed where can i get a manuel for repair to this tv.
When i turn on tv i get a loud humming noise its a polaroid model num t370xw01
Posted on Aug 25, 2011
  • 320 Answers
Please refer to the link below for the manual and schematic diagram of Polaroid FLM-3732
http://www.retrevo.com/support/Polaroid-FLM-3732-TVs-manual/id/279ag019/t/2/
Posted on Nov 07, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
Panasonic th-42px600u high pitch sound
likely a coil or small transformer in the set is vibrating hard enough to make it squeel, it would have to be located with back off by listening to see where it comes from.
cure would be to replace the entire board it is on or hot glue the part that is causing this to dampen the sound.
If it is coming from the front screen unit that is a more serious issue.
Dec 23, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
High pitched ringing sound from my tv
It most likely is coming (based on model number listed here) from the high voltage transformer---ways to silence that up to and including replacing that part.
Jun 16, 2012 | RCA HD52W59 HDTV Projection Television
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
I have a Hitachi Ultra Vison 57S700 2004 model, the TV has had a slight high piched whine for a couple of weeks and today the screen went green then black and the sound was gone. When it is turned on the...
This tv is under five years old?Yes,it is worth fixing.Over five,i would compare the prices for a new LCD tv and the quote priced from the Tv Tech.for the old tv.This tv have high voltage problems around the Deflection circuitries area.Could be any things burn in this area.The high pitched whine sound,i'm sure it is from the FBT-the high voltages flyback transformer,high voltages current have no where to go.Must hire a tv tech. to troubleshoots and replace parts on the Deflection circuitries area.Also the FBT could be dead too,because HV Current bounces back forth and have no where else to go.The prices to troubleshoot unknown problems is about $400 bucks and plus cost of replacement of parts.
Dec 04, 2010 | Hitachi 57S700 57" Rear Projection HDTV
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
High pitched sound
The high-pitched squeal is from the power supply, usually because of failure of the horizontal output transistor, flyback transformer, or both. Without a specific model I can't give more definite information about part numbers or likely costs. But repairs of this type usually have parts costs in the 10 to 75 dollar range (depending on just which parts are bad, and where replacements come from) plus whatever labor costs the repairer charges.
Nov 13, 2008 | Televison & Video
RCA F20632SE 20" TV
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 01, 2017 | RCA F20632SE 20" TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Televison & Video Logo
235 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
