Question about Sony PlayStation Portable (PSP) Console
I cannot get a internet signal even though my house is wired for wireless internet
Every time i try to enable wma it says there was a connection error
    Scholar:
  • 65 Answers
What kind of firmware are you using??Make sure you have the last one or check the web for Custom firmware
Posted on Jun 18, 2008
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Cannot enable wma playback. don 't know ssid number
You could only enable your wma playback by connecting your psp to internet, ssid simply means wireless network name. If you are trying to connect to internet you will be ask for ssid which means that you should be in a wifi area to connect you to the available network name.
Jun 21, 2009 | Sony PlayStation Portable (PSP) Console
Enable wma
The problem was probably McDonald's and not your PSP's. Have you tried connecting to a different signal?
WMA is related to Windows Media Player files and not the internet.
May 11, 2009 | Sony PlayStation Portable (PSP) Console
Enable wma play back with out wirless inter net
If you want to enable WMA playback, just go to the Recovery Menu of your PSP (do this by turning OFF your PSP [hold the off button up for about 10or more secs until your PSP completely shutsdown]
then go to REGISTRY HACKS> then you should see there the choices for BUTTON ASSIGN, ACTIVATE WMA PLAYBACK, and ACTIVATE FLASH PLAYER...just press X over ACTIVATE WMA PLAYBACK (it should be highlighted in RED) then you're done! Hope this helps!
Sep 04, 2008 | Sony PlayStation Portable (PSP) Console
Cannot Enable WMA Playback
what ever you do, DO NOT RESET SETTINGS cause then you just have to reset them and it wont do you any good. I had the same problem. The most lodgicall way to solve this is just to spend like 3 bucks at mcdonalds and get the wifi so you can play online multiplayer, go on the internet, and fix the wma feature. Or you could just free load off of a friends wifi or wirless setup. But you may have to enter a security code.
Jan 11, 2008 | Sony PlayStation Portable (PSP) Console
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
ENABLE THE WMA ON THE PSP
You need to have wireless internet/router connect to modem(adsl/dsl/cable modems) no dialup .When you have the wireless connection set it up in the internet settings and select the setting to be on automatic and then go and enable WMA playback and then it will download and you should be able to play wma. Another alternative is to use an audio converter such as dbamp or sound forge?(use google)
Dec 05, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
