Question about Zenith XBV442 DVD Player/VCR
DVD tray will not open.
My mother's Zenith XBV342 dvd player will not open so she can retrieve the disc. When she presses the open button, the readout says "open" but the tray will not slide out. She has tried to gently pry the tray open, but it won't budge. dvd tray not opening found no hole for paper clip
    Guru:
  • 859 Answers
The disc is dislodged and jamming the drawer. You have to remove the cover, about three, maybe four screws, and then take the disc out to resolve the problem.
Regards,
Worldvet
Posted on Jun 15, 2008
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
The problem could be that the eject motor drive belt has come off.
Apr 18, 2009 | Zenith XBV342 DVD Player/VCR
Progressive scan mode on screen
Your television probally does not support progressive scan mod. many do not.
Apr 12, 2009 | Zenith XBV342 DVD Player/VCR
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
How do you turn off Progressive Scan mode DVD for this model??
Hello
Yes I fixed this problem.
Took out the DVD and closed the tray. I held down the STOP button on the remote for 10-15 seconds and the "Progressive Scan Mode" went away. Has not returned. Thanks!
Apr 05, 2008 | Zenith XBV342 DVD Player/VCR
Try this take out the disc,close the tray then push the stop button for 10 seconds.Suerte
Mar 28, 2008 | Zenith XBV342 DVD Player/VCR
Hi All
I had a similar problem with my fathers XBV342, my problem was that the DVD tray would open but when a disc was inserted it would close then open again time after time.
I took the top off of the unit and the front cover fascia panel off then checked the tray movement, I found that the belt for the tray motor located near the front of the tray was loose, which meant that the motor did not raise the drive motor to its correct location, which in turn didn't allow the motor to turn the disc, this causes the tray to open again, I guess it thinks it has a misaligned disc and ejects the tray, I hope this helps someone.
Jun 03, 2007 | Zenith XBV342 DVD Player/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Zenith XBV442 DVD Player/VCR Logo
428 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
