Question about Making Memories Folding Paper Trimmer
Where can I get a replacement for broken plastic paper grip?
    Master:
  • 752 Answers
Unfortunately no, the company went out of business quite some time ago, replacement parts are virtually impossible to find.
Posted on Oct 02, 2015
    Top Expert:
  • Making Memories Master
  • 9,098 Answers
Check with google or E-bay
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
Brother M-100 Won't Grip Paper
Best way is to remove the top cover, with out taking the Platen(large rubber roller) that the paper goes around out look to the rear there is a spring that breaks that puts pressure on a pan with feed rollers in it , replace spring or at least put a new hook in it or if you are lucky and it is not broke I could just be unhooked. Also clean all those rollers that are rubber with something nail polish remover. Do not touch plastic with this cleaner, it may melt plastic.
Apr 04, 2014 | Brother Office Equipment & Supplies
My printhead carriage hits the rail right underneath it. The rail contains small plastic blocks with metal rotors, which guide the paper through the printer. The carriage hits these rotors, which creates...
Sounds like the starwheel motor assembly has broken its gears. It lifts the starwheels up so you can load paper, then lowers them back down to grip the paper while printing.
Part number is:
Q5669-60697 Starwheel Motor
and should come with new firmware to help prevent future breakage.
It is a little difficult to replace if you have never done one before, but should come with instructions. There are you tube videos on how to replace this and I have a link to the service manual replacement procedures here as well. Good luck !
parts removal replacement procedures
Aug 21, 2013 | HP DESIGNJET T1200PS 44IN 2ROLLS 32GB RAM...
Hood release wont open
I am now guessing the plastic handle has broken from the cable. If you get a pair of vise grips, and tighten them on the cable(real tight), you can pull the vise grips and the hood release should pop open. I can tell you now, the replacement part is a dealer item only. With a little patience, and time, you can replace it.
Dec 31, 2010 | 1998 Cadillac Catera
Xerox m15i copier guide broken
This sounds like the paper path guide that sends the copy by the drum modual and then to the fuser.
If the walls are stained yellow, they the "vains" plastic guides are broken and will cause paper jams. Also after the paper has been fed out of the fuser modual there are other plastic guides that might appear to be yellow in stains. these tips often break and will cause constant jams.
The door guide has to be replaces and the vertical transport may need replacing as well. You would need to get part numbers for this specific model and someone who knows how to dissasemble this machine.
End result, you may need to call Xerox for assistance.
Good luck.
Oct 16, 2009 | Xerox WorkCentre M15i Laser Printer
MY HP PHOTOSMART C7200 ALL-IN-ONE WILL NOT RECOGNIZE THE PAPER
Try cleaning the paper rollers with alcol to remove impregnated ink which causes the roillers to become shiny. It is failure to grip the paper that usually causes this. use a plastic pot scourer to gently roughen the platten roller to allow it to grip better.
Jul 25, 2009 | HP Photosmart C7280 Laser Printer
Plastic Guide rail on sunroof broke
I just purchased a used yukon xl. Both plastic rails are broken.
Solution: Drill out the blind rivet. Start with 1/8 drill bit and remove the head off. The plastic broken part can now be removed.
Install a blind rivet through the new plastic rail and use the rivet gun to squeeze the rivet in place. Make sure it is the right length.
get a grip gage and determine the right rivet for it.
very easy job.
Jul 01, 2009 | 2003 GMC Yukon XL
Brother DCP-7020 Drum problems
Open the front of the printer by pulling on both tabs at the finger grips on both sides of the front panel. The front panel will flip down. The drum and toner cartridge comes out as a single unit. It is black plastic within gray plastic and has a handle like grip in the middle. Grasp this grip and pull the unit up and out. It feels kinda funny the first time you do it and you may feel like it will break, but it won't. Pull it up and out in a kinda circular arc. Do not touch the drum. If you ever need to replace the toner cartridge, press on the blue tap and separate the drum from the toner cartridge. You will have to replace the drum after every five toner cartridge replacements so practice doing it now. Note the tabs and slots on the sides before separating the drum and cartridge. Align the cartridge into the drum carriage and slide it in until it clicks. To replace the cartridge assembly into the printer, angle the cartridge at about 45 degrees and rotate in while pushing. It should click into place. If the front door then closes properly, you should have it in properly. Practice a few times and you should be an expert. For paper jams, there are many places to check and they may not all give warnings. First pull out the paper tray and check for and remove misfeeds. Remove the drum cartridge assembly and described here and check for and remove any paper. Open the back cover and check for and remove any paper. Open the automatic feed and check there as well as lifting the cover where the scanning surface is. Look in the rollers for the automatic feed for paper pieces. The last place almost never gives you a warning. Reach into the slot where the paper exits after being printed and grasp the whole top cover. Lift upward and it will open about 4 inches. This is a good place where small pieces of paper or even whole sheets may get stuck. Clean out any dust while you are there.
Sep 26, 2007 | Brother DCP-7020 All-In-One Laser Printer
Making Memories Folding Paper Trimmer Logo
243 people viewed this question
Top Making Memories Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Making Memories Measuring Tool and Sensor Expert? Answer questions, earn points and help others
