Question about Acer Aspire 3690-2196 Notebook
Operating system not found media test failure will not reboot aspire 3680
When i start will not boot gives me the black screen says the above mentioned problems operating system not found media test failure will not reboot bios cannot find hard drive. if i install recovery disk will i loose all data.
  • 2 more comments
  • Anonymous Aug 18, 2008
    when i start will not boot gives me the black screen says the above mentioned problems operating system not found media test failure will not reboot bios cannot find hard drive. if i install recovery disk will i loose all data.
  • naitu83 Dec 05, 2008
    I have an HP dv9000 laptop. Ocassionally it starts up with a few beeps and a blank screen saying (operating system not found). I have two hard drives, I doubt either of my hard drives are fried. Both works perfectly. Any one with this problem? any help is appreciated.
  • bobs1450 Dec 08, 2008
    my acer will not boot up and all i have is a black screen.will not do anything.
  • Anonymous Dec 14, 2008
    Just got a new hard drive for my Acer 3680. I popped in the Windows XP disk and it just shows a black screen on startup. Can't install windows. HELP!!!
    Champion:
  • 381 Answers
Hi..try to remove unplug or plug in the Hard Drive,, if cant work you or nothing happens you need to re-place the hard drive.about files theirs nothing ways to recover the files if the Hard Drive is totally defective..Thanks..and GOOD LUCK...^_^
Posted on May 13, 2009
I was told by pc world and acer that is most probs the hard drive has failed. However they said it could be a lose cable withing the laptop.!
i have the same prob. sounds like a few hundred pound to repair.!
Posted on Dec 30, 2008
    President:
  • Acer Master
  • 1,314 Answers
If you use recovery disk, yes you may lose all your data however it sounds like the hard drive has crashed anyways and you'll need a new hard drive.
Posted on Jun 15, 2008
  • 130 Answers
You need to replace your hard drive, as the other one is toast, I doubt very much its the controller, or a software issue, try a new hard drive and your problem will go away.
In IBM system X3550 M3 server pxe e61 media test failure check cable error is coming and when i mam trying to install OS Partition will not show. pls give me solution.
This sounds like you are asking two different questions. PXE booting would be the way you would begin installing or loading an operating system. "Media test failure" errors would indicate a lack of network connectivity on the network interface that you're trying to PXE boot from.
You go on to mention an OS partition not showing... So did you resolve the PXE media test failure issue?
Your question is unclear and unanswerable in it's current state. BE CLEAR, CONCISE AND SPECIFIC.
May 26, 2014 | IBM Computers & Internet
When I turn on my emachined620 laptop I am informed PXE-E61 Media Test Failure then Operating System Not Found. How can I sort this problem
If you using your nb with network boot os media, please re check your cable connection to server media. Or
If you using internal hardisk for boot up your system operational you might have accidentally change Boot Order on your BIOS setup.
How to enter bios:
On power on you might see instruction on the bottom of your screen like => Press F2 to enter setup or some thing like that.
Make sure to disable Network Boot option, or move it to the bottom / last of Boot List Option
Press F10 to save it, and reboot
Nov 15, 2012 | eMachines eMD620-5133 Notebook
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
T 43 says "operating system not found"
Sounds like you have a bad hard drive. Boot up with a Windows CD and select repair at the setup menu. It should dump you to a command line. Type "chkdsk /f" without the quotes and it will check the hard drive for errors. When it's done, reboot normally and it should get you into windows. If it doesn't, replace the hard drive and install windows on the new HDD.
Oct 26, 2009 | IBM ThinkPad T43 Notebook
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Toshiba Satellite PC ... Operating System not found
Enter BIOS by hitting F2. Go to Boot tab and change to default boot. I had the same problem and it worked for me.
Mar 03, 2008 | Toshiba Satellite M30 Notebook
Acer Aspire 3690-2196 Notebook Logo
1,325 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
