Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
My Dyson DC07 is screaming load. I have replaced the lifetime filter and the hepa filters. I also replaced the clutch and brush. I took the canister apart and cleaned it. It works, but is so loud something else must be wrong
SOURCE: beater bar does not work dyson DC07
If the beater bar does not spin freely, and the belt still seems to be in place, then you may not need a new clutch, but you may need to reset the clutch.  This is done very simply by keeping the beater bar section of the vacuum flat on the floor and reclining the handle all the way to the floor so the entire vacuum lays flat. There is a mechanism in the vacuum which resets the clutch. You will probably not hear anything when the clutch resets.  I sat on the phone for an hour and a half to hear this simple technique is built into the vacuum, but excluded from all instructions and website customer service information.
Posted on Oct 22, 2007
SOURCE: Dyson DC07
http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
Posted on Mar 19, 2008
Agent Don
  • 310 Answers
SOURCE: dyson animal will not stand up and question concerning lifetime hepa filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=34163&thid=630085
Dyson animal will not stand up and question...
Posted by madmimi on May 28, 2008
my dyson will not stand up by itself=catch seems to have failed and online instructions from dyson have not solved the problem- can anyone help
my second question is will dyson replace my lifetime hepa filter that is located beneath the debris collector, it is very black and is not washable
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
In answer to your 1st question, you may want to check with a factory authorized vac dealer who does repair on the Dyson vacuums to see if they can correct the problem, or call the Dyson factory phone # listed below for the nearest vac dealer in your area. 2nd question. The Hepa filter is mostly a wear item and I was not aware of the lifetime Hepa filter and that also would be a good question for the factory to answer, I could not find an answer to the questions and they might be able to clarify the answer to both your questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.dyson.com/
Dyson Inc. 600 W. Chicago Suite 275 Chicago, Illinois 60610
Customer Service 1-866-693-9766 questions@dyson.com
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on May 28, 2008
  • 7 Answers
SOURCE: removing the filter on Dyson DC07
on the 07 model it is on the right side push clip and pull inside will be a foam filter wash and dry
Posted on Dec 04, 2008
SOURCE: Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Posted on Oct 29, 2009
How to change belt in dyson upright model dc07
Hi there, it's Jack at Dyson.
There are two versions of DC07 - some include a brush bar which rotates all the time when the vacuum is running. And some include a brush control clutch mechanism which allows you to turn off the brush bar for hard floor cleaning. If your machine has the brush control, you'll see the dial on the front of the cleaner head.
If you have a DC07 without the brush control feature, you can replace the belt as shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if you have a DC07 with the brush control feature, the clutch mechanism uses belts engineered to last the lifetime of the machine in normal use. These are not designed to be replaced by the user, and we would advise against attempting to change these as damage may be caused to your machine.
For further advice on having your machine repaired, or to order replacement belts for a DC07 without brush control, please contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Where is the brush belt on a dyson 07 upright vacuum?
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 original where are the filters are they washable
If you have the machine in front of you, with the front of the machine facing you, then the filter is located on the bottom right hand side (just a little lower than the bottom of the clear cylinder). If you look closely you'll see a little embossed picture of a filter on the plastic. You'll see a button with an arrow on it. Press the button and the whole section simply slides out in an upward motion.
To remove the filter, remove the whole of the inside of that section. It can get rather difficult to remove due to gritty dirt build up, but it will eventually come out if you grab the yellow 'spokes' and jiggle the filter clockwise and anticlockwise whilst pulling at the same time. When you get this part out you can remove the sponge filter. Both the sponge filter and the filter holder can be washed by hand. Although they recommend just cold water to rinse it through, mine is usually too dirty for just that and I use lukewarm water and a bit of washing up liquid.
Make sure it's fully dry before you put it back in (let it dry naturally, not on a radiator). HTH.
Aug 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you clean the HEPA filter on the Dyson DC14 Animal Vacuum
DC14 has two filters, a pre-motor filter and a post-motor filter. Both are engineered to last the lifetime of the vacuum in normal use, but only the pre-motor filter requires maintenance.
We recommend washing the pre-motor filter at least once every 3-6 months using cold water without detergent, as shown in the video below. Always ensure it's completely dry before replacing it - this could take at least 12 hours.
The HEPA post-motor filter does not require any maintenance. We advise against attempting to wash or clean it in any way as this could cause damage. It's normal for the filter to discolour over time, as it's engineered to capture the carbon dust from the motor brushes. This will not affect performance.
I hope this helps, but if you'd like any further information you're welcome to contact our experts directly at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 11, 2014 | Dyson Slim DC18 All Floors HEPA Bagless...
My manual says it is DC07, but it is pink and silver in colour. I have 2 problems, firstly the brush has stopped spinning, but belt appears intact. Secondly there are tiny holes in suction pipe near...
The DC07 came out in a few different variations so the colour only indicates that yours has a hepa filter. The first problem can be caused by a few different things
1. the brush roller bearings are worn or siexed.
2. The clutch to motor belt is brocken or off the drive shaft (this model has 2 belts but only one is visible without pulling the head apart.
3. The machine is set to hard floors (check the dial on the front)
4. The clutch is faulty.
I have made a video called
How do I check the clutch or brush roller of my Dyson DC07?. (video)
Folllow the link to my website and choose that video, it will show you how to fix all these problems. The same video will show you how to replace the internal tube as well.
If you need to purchase any parts for your dyson check out nelson vacuums or vacuumspot.
Finally if this is a helpful answer please rate it or better still leave a testimonial.
Jan 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
Jul 14, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you remove the HEPA filter on Dyson DC07
I use a screw driver to pry them up.
Joe
Nov 07, 2009 | Dyson Vacuums
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson animal will not stand up and question concerning lifetime hepa filter
Go Ahead. Use Us.
May 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
430 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
