Hitachi HD TV Power Switch Failure
I turned the TV on with remote and the red led illuminates, I heard a repeated clicking noise, but the TV never came on. I removed the panel and tracked the noise. I removed the cap of a black sensor that has a tiny spring like system and two thin flat copper strips that connect each time the click happens. I removed a tiny buss fuse and the clicking stops.
  • Danthe1 Oct 19, 2008
    I have a hitachi,model#42HDS52A , I turn the tv on,it shuts off. I unplug the power cord and plug it in, then the tv works well. Any suggestions?
  • 8,617 Answers
The black box is susposed to click once when power is supplies and then once when power is shut off. If its a repeted clicking it needs replacement. Its called a relay. Whats the model number of your set/ I will be able to help you if you post thye model number for me.
Posted on Jun 15, 2008
Hitachi C2143S TV
you have a very unhappy tv...sounds like you have a relay clicking, or worse, something about to fail. the led pulsing is a warning signal, and going pure red means that you have a major failure inside the box.
you doing the service yourself, or open to a service pro coming in for this?
Mar 07, 2008 | Televison & Video
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Dec 29, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Need code for hitachi tv
Hitachi: 1145, 0145, 0151, 1904, 0032, 0409,
or you can use the general method:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Apr 04, 2009 | Radio Shack 15-2142 Remote Control
Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Feb 17, 2008 | Televison & Video
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
