Question about Hoover Dryers
My hoover hnc180 condensor dryer capacitor has gone how do i strip the machine to get to the motor.
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my hoover nextra megalaod condensor
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 21, 2011
heatman101
  • 43501 Answers
SOURCE: no hot air from my
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 05, 2011
How do i get access to the motor on a hoover vhv781c tumble dryer as i need to replace the capacitor
Hoover vision hd tumble dryer VHC680F 16/10/2012 ...
? 0:19
https://www.youtube.com/watch?v=WCiQ9qc2TWk
Oct 16, 2012 - Uploaded by Ben Smith
Ben did you manage to change the capacitor? I got the same problem but I cant actually get close enough to the capacitor to replace it!.
Nov 26, 2015 | Hoover Vacuums
How do i replace the capacitor in a hoover tumble dryer
the motor start capacitor ???
this is mounted beside the motor
you take it off and you place a new one
Jan 10, 2015 | Hoover Dryers
How to get to motor on hoover vhc691b?
Very rare a motor fails on a hoover drier normally its the capacitor that fails. you can hear the motor humming but the drum wont rotate to proof its the capacitor turn the machine on press start listen for the motor humming open the the door of drier turn the drum by hand fast then shut the door as fast has possible then the drum should start going around . then this proves its the capacitor fault you are doing the job of the capacitor giving the motor a start .
May 16, 2014 | Hoover HDC6 Electric Dryer
No hot air from my Hoover nextra8 HNC180
heatman101
Sep 05, 2011 | Dryers
Our Hoover (3535d) dryer tumbler does not want to spin although you can hear the motor starting. The load does not appear to matter. There is no sign of belt slipping. Can the problem be due to the start...
If you hear the motor starting then it normally wouldn't be the start capacitor. It is when it doesn't start that you suspect the capacitor.
If your motor is turning and belt is NOT slipping then your drum should be turning! Those things do tell you that your electronic (control board and timer) are good, but you are wrong about either the motor or the belt!
Jul 03, 2011 | Hoover Dryers
Just moved into a house in Singapore with a Hoover D6786 dryer. It starts up and spins but repeatedly stops spinning after only 5-7 minutes. Clothes will not dry. What's up? Thanks for any help.
This is normally the sign that the electric motor start/run capacitor has gone faulty: the special motor start/run capacitor, usually around 4 to 10 uF / 450v, helps the motor during the stop/start sequences which require higher torques.
Aug 05, 2010 | Hoover Dryers
Dryer heats up but drum doesn't turn.
If the drum is very stiff to turn could be the drum bearings shot which would account for the broken belt, replace belt and it liable to break shortly after again. hover are known for there bad bearings and they cost a small fortune.
check it out have a look and see if there is nothing jaming the drum inside, i am certain your belt has gone and maybe down to the stiff drum making belt break, replace belt but bare in mind it may break again if the drum is too stiff.
choice is yours really. bearing kits cost more than 50 quid in general
Jul 10, 2009 | Hoover Dryers
Hoover Condensing dryer malfunction
Hi Mike,
The motor probably has experienced locked rotor current and fried the windings. Of course the capacitor could have shorted. If you can find it, look at the capacitor and if the can looks like it's lid is swollen or pooched out, then go for replacing the Capacitor. If you remove the motor and smell the case and it smells burned, you motor is shot. It does not have to lock down to be bad. The windings do not rotate in an AC motor.
Nov 02, 2007 | Hoover HDC6 Electric Dryer
Dryers Logo
91 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
