Question about Olympus X785 Digital Camera
My olympus X785 is giving problems. the lens is coming out but it just makes a clicking sound and it stays out and the screen is blank? what do i dao?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 08, 2010
My camera turns off with the lens half way in, and when i try to turn it on it makes a beeping sound and the red light flashes . the screen stays blank/black, whats the problem how can i fix it??????
Hi, it could be that the lens got some dust or even sand particles between the lens covers. You might need to take it in to your local camera repair shop for a more detailed answer, but I had the same issue with my lens cover that only closed half.
Hope this helps.
Regards
Jun 28, 2012 | Olympus T100 Digital Camera
My screen dont work can it be fix?
New LCD screen can solve your problems for your digital camera
Jun 21, 2011 | Olympus X785 Digital Camera
My camera's lens doesn't come out any more. It is fully charged and when i switch it on it makes a weird buzzing sound and the lens stays firmly in place. Is it worth getting it repaired or what is wrong...
You should first try to clean out the lens and the area around it. There possibly could be some trapped dirt in one of the nooks and is preventing the camera lens from sliding out properly. Try tugging a bit on the camera lens to see if it gives, that may knock whatever is holding the lens back. If all else fails, you should take your camera to be repaired, Olympus has great customer support so you'll be in good hands.
Mar 06, 2011 | Olympus FE-20 Digital Camera
I have an Olympus X785 which is having problems focussing on shots in the dark or dim light. Any help appreciated
Some cameras have a low light focussing light built in. If yours doesn't, then you will experience problems in low light.
Dec 07, 2009 | Olympus X785 Digital Camera
When I turn on camera it makes a ping ping ping sound
BAD CCD PROBLEM
i had the same problem with my camera and got it repaired FREE from Olympus just call them and ask them abt BAD CCD they know about this problem
pls rate me well
Regards
Aug 10, 2009 | Olympus FE-330 Digital Camera
Olympus FE 270 Digital camera lens, screen, etc not working
Hi!
Hi!
The focus is stuck. Could be sand, dirt or something in the focus gears - well known problem for these lens. Contact your local Olympus service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
Tom
Jul 03, 2009 | Cameras
Olympous Master Camera Problems
If the lens stays out then it would appear to be the fault lays there.
Check with Olympus support or in the camera is still under warranty retun it to the seller.
There is no self repair option.
Aug 22, 2008 | Olympus FE-280 Digital Camera
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Olympus X785 Digital Camera Logo
156 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
