Question about Garmin nuvi 1350 Car GPS Receiver
My unit comes on clear as a bell until I plug into either of my two cars, then the screen darkens and is impossible to read. I have tried the day setting and the night setting and the automatic setting...thanks
  • Garmin Master
  • 587 Answers
It sounds like you have the power switched to the far left when on charger plug, make sure its in the middle
Posted on Nov 07, 2010
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
Blinking mini notebook screen
Your notebook/mini is designed to power down the screen if your battery begins to lose charge, and this may be considered normal until the battery is recharged.
Try replugging the power then press the power button to take it out of standby mode. If it still hangs on the blinking light, you may need to update the bios or change your power settings in bios to either S1 or S3 and see if that changes anything.
Mar 09, 2010 | Dell Inspiron Mini 10 Notebook
When i plug in and turn on my external dvd burner,
1. your unit is having a hard time with the compatibility of the computer.
2. contact the tech support of the manufacturer and see if there are updated drivers for the unit.
3. You may have a hardware conflict. This is rare these days but not impossible.
Jan 06, 2010 | Gear Head Computers & Internet
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
I have a blank screen. The unit lights up but i can't input data.
It is possible that the screen is too light to see anything. If that is the case you can try to darken the screen a bit to verify if it works.
To do so:
Press and hold the UP arrow to darken the screen. Keep pressing until it is dark enough.
If that does not work, you may have to follow the link to the TI FAQ and Knowledge Base to an article that addesses the question of a graphing calculator not turning on.
Hope it helps.
Nov 10, 2009 | Texas Instruments TI-83 Plus Calculator
Screen darkens, very faint picture, sound still works. This is intermitent problem happens day or night in car plugged into car power. Thank You
go into the settings and turn the brightness up when the unit is plugged in and when it is running on battery mode (when it is plugged in it automatically goes into behicle mode and dims the display)
Oct 23, 2009 | Garmin nuvi 1300 Car GPS Receiver
When i try to graph something on my TI-83 Plus, the screen fades to pitch black and then it says INVALID DIM
Reset the RAM to clear old settings that interfer with your new problem
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER].
Press [CLEAR] to clear the screen.
After a memory reset you may have to adjust screen contrast.
To increase contrast (darken the screen)
1. Press [2nd] key and release it.
2. Press [UpArrow] key and release it.
3. Repeat sequence until screen darkens enough.
2. Press [DownArrow] key and release it.
3. Repeat sequence until screen lightens enough.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-83 Plus Calculator
My packard bell pc just stopped working
I think This is BIOS problem so
open CPU box and clear bios settings...
oterwise change tha mother board
TENNISON J
Mar 28, 2009 | Computers & Internet
Sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Jan 21, 2009 | Sub-Zero 700TR
Garmin nuvi 1350 Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
