Question about Husqvarna Chain Saw 20" Bar
Husqvarna 340 chainsaw will only run for a few seconds on choke, tried cleaning carb, carb adjustments do not help. will not run at all with choke off.
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other problems. Make sure that you have fresh fuel mix in the tank (50:1 ratio). Mix the fuel/oil in it's own container and shake the container thoroughly just before adding to the tank each time to prevent oil starvation. When you were cleaning the carburetor, did you check the condition of the lower diaphragm for flexibility with no holes or cracks? Turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. Start the engine and allow to warm up, then pull the throttle full on. Adjust the H jet needle CW until the engine starts to speed up. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW for better idle, but allows the engine to 'follow the throttle'. Hope this helps!
Posted on Nov 07, 2010
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
My husqvarna 350 chainsaw starts but wont stay running for more than a few seconds
Eric:
Find the gas/air adjustment screws on the carb (next to the the throttle cam where the throttle cable attaches. Turn the screws in all the way... GENTLY... Those are needle valves, and too much torque on them will damage the needle valve seats. turn both of them out one and a quarter to one and a half turns. Start the saw, and adjust one or the other screw in or out until the saw runs properly. If there is a plastic stop installed on the screws, remove it first, and replace it after the saw is running properly. You have to be patient while tuning the carb as it may take a while. If you adjust too much and the saw refuses to start at all, start over with the 1-1/4 to 1-1/2 turns out on the screws.
Aug 19, 2012 | Husqvarna Garden
Chain saw starts hard, have to start it with the choke on all the time wheather the engine is warm or cold. the engine will not idle with out it stalling.i replaced the spark plug,thefuel line,fuel filter...
Sounds like dirt in the carb. Pull carb apart and spray out real well with gum cutter or carb and choke spray. Be sure to remove the needle valve and rinse all holes and ports. Use COPPER wire, like a strand from automotive or speaker wire to run through each hole. rinse everything a few times
Feb 20, 2011 | Husqvarna Garden
Husqvarna 142e will not stay running. Going through the sequence of full/half choke it will start and run at high rpm when choked. Even after warmed up, it will die within a few seconds after dropping the...
If it is only running high at full choke - then it is not getting enough fuel.
You've cleaned out the whole thing - so it's not air that's the problem. It's running - so it's not a spark problem - it's a fuel problem.
If you have a fuel filter - change it out or clean it properly. If the fuel line is clear, then you need to adjust the running setting of the carb - there are usually 2 setting knobs -one for idle - one for running / mix.
You need it running richer till you get it going - then trim it back to stop it smoking and get a good rev.
Aug 28, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 55 chainsaw won't stay running.
It has a crack in the fuel line between the body and the tank. The crack lets air in the line. Replace the line.
Jun 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Oct 06, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Chain Saw 20" Bar Logo
774 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
