Televison & Video Logo
Posted on Sep 07, 2017
I have a Zenith TV with the original remote. How do I enter the code in the remte to control other devices, IE a magnavox DVD player(I can not fide a code entry button anywhere on the remote) or is there a free manual online for this particular Zenith TV? The model # for the TV is A32B43W and the #s associated with the remote are 124-00233-01 and below that is MBR3457Z
bubbab
Level 1:
Habit-Forming:
  • Contributor 18 Answers
  • Posted on Nov 26, 2017
bubbab
Contributor
Level 1:
Habit-Forming:
Answers
18
Questions
0
Helped
5350
Points
33
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Nov 28, 2007
SOURCE: zenith tv model sy3272dt
there should be a video input on back of the tv you can use, (red,white and yellow colors) this set I believe had more than one input. that would work for you dvd
Anonymous
  • Posted on Feb 10, 2008
SOURCE: lost tv codes
I CAN'T TURN MY TV WITH OUT MY REMOTE
I DON'T HAVE THE CODE
A
Anonymous
  • Posted on Feb 20, 2008
SOURCE: Zenith ZN-501S remote control codes and instructions
http://www.thompsontv.com/zcodes.html
Anonymous
  • Posted on May 22, 2008
SOURCE: Code for zenith remote control for toshiba tv
I found the code
Anonymous
  • Posted on Jun 20, 2008
SOURCE: Zenith remote codes
i have a nenith remote but lost codes and i have a vcr /tv combo unit tashiba what are the codes ?
How to program the remote control for a Zenith VCR and DVD combination player go to
If it is the original remote control for your TV - VCR & DVD it doesn't need programming but guess it's not, so you can't program it.
You need some unviersal remote where all three devices shold be listed, and code it setting for each devicer
2helpful
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
1helpful
2answers
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
I need remote codes for an innovage jumbo remote for a zenith vt and magnavox dvd player , the innovage website does not offer the codes. Thanks.
Codes for Zenith TV
000 001 0023 004 038 058 059 064 121 073 135 136
Magnavox DVD player
173 183
thanx
2answers
I use URC-3021 w/ Magnavox TV. I bought a
It sounds like you would like to re-assign one of the function buttons on the remote to control a different device. If you would like to program the CBL/SAT button to control a DVD player, here are the steps:
  1. On the remote, press and hold SET until the LED blinks twice, then release SET.
  2. Enter 9 9 2. The LED will blink twice.
  3. Press DVD/VCR once.
  4. Press CBL/SAT once. The LED will blink twice. The CBL/SAT key is now ready to be set up to control your DVD player.
To setup the CBL/SAT button to control your Magnavox DVD player, follow these steps:
  1. Turn on your DVD.
  2. On the remote, press the CBL key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the following list: 0503, 0675. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the DVD and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
3helpful
3answers
CANT FIDE CODE
Ask them, they are specialized in finding remote codes
Need code to program a universal remote!
general process for a universal remote control:
  1. push and hold setup 3 seconds
  2. select the device to control (TV DVD etc)
At this moment TV has to be ON (turn tv on by front panel)
3. continue with remote control pushing power button again and again and again SLOWLY
4. when the tv turns off then press enter to save your code.
Codes for my dvd player and zenith vcr
Most remotes use the same code sets. Here's what Radio Shack says for your brand:
dvd: 0503,0539,0646,0675,0821,1268,1914
vcr:0000,0039,1137,1479
let me know how you made out.
31helpful
6answers
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
